chrisrutter
Hi everyone. I've not posted anything here for a little while as I sold all my motorcycles in anticipation of a house move (which has been postponed) and was also trying to reduce possessions generally. My lovely CL450 was the last to go, which I miss very much. However, having always owned a motorcycle of some sort I couldn't pass up the opportunity to rescue a 1974 CD175 which I found on ebay locally for a couple of hundred quid or so. I had a CD175 a few years ago, which was in a very bad state when I bought it, that I built up into a trials-esque type of thing with 18" wheels and TLS front brake and a few other bits. It was a very nice little bike, very easy to run and maintain and with the advantage that I could manoeuvre it out of my garden gate without too much trouble. So I was pleased to acquire this latest CD175 which is in much better condition. It has a V5 registration and it had apparently sat in a shed for at least 20 years.
Here she is as found -
It's missing some bits like exhausts, side panels and tank panels, but these can all be found relatively easily I hope. I've already got a few bits like the sprocket cover, one tank chrome panel and the front engine mounting plates and will be on the lookout for other bits as I go. I was very pleased that all the engine fastenings including the cylinder nuts and cover screws came off without too much trouble using the impact driver. The carb was in really good condition and still worked off the throttle grip, as did the clutch. The front brake also worked! The wiring looks ok (although it will need a good going through and I might add one of Sparckmoto's 6v reg/rec as I've used them before and they have been excellent http://www.sparckmoto.com/Products/Charging-and-Regulators). Things like the switches, lights and seat will all be serviceable with a bit of work. Mudguards are ok, too, but may need a bit of repair where the stays bolt on. The rims and spokes may be too far gone to safely use.
Inside of carb - quite clean and free moving with passages and jets clear.
Everything was going so well that I thought I would have a look in the oil spinner and see what state that was in. In trying to get the cap off by removing the screw in the middle and then winding in an 8mm bolt I encountered my first set back, which was entirely of my own making. The bolt sheared off leaving the end stuck in the thread of the oil spinner cap! The cap was moving and I thought 'just one more turn and it'll pop out'. However the bolt I was using was obviously not very strong and it snapped!
I know I thought - I'll nip down to B+Q (DIY supply shop in UK) and get some 'easyout' type stud removers. Drilled a hole in stud (off centre naturally
) and tried to back the remains of the bolt out with a bit of heat. No movement at all and I was starting to mess up the treads of the cap. Hmm, what a pickle!
I'm thinking of trying to make some kind of puller or slide hammer to fit inside the holes inside the cap and trying to pull/yank it out or I might have to try carefully sawing the spinner cap out if all else fails. Although there's a good chance I'll ruin the spinner cup as well doing this. (I see CMSNL have both in stock in case I do mess it up). Any suggestions as to the best way forward are more than welcome!
Anyway it was all going so well up to this point and I am pleasantly surprised by the condition of things once I got them apart. The engine is stuck at the moment but I've put some oil down the bores which might help release things. I imagine it's just stuck rings but I'll take the engine apart in due course to see what is going on there and maybe there will be a clue as to why it has been laid up all these years. There's only 14k on the clock and I don't think it's been on the road since the '80s so fingers crossed it's just been laid up and forgotten about.
I think the immediate plan is to get things apart then clean, repair and replace them as necessary and then try and get it back on the road. It looks a bit ratty at the moment but I think I might try and rebuild it keeping as much original as possible, including the paint and chrome as it's not really that bad and, as they say, it's only original once.
I'll post up further progress as it happens and it's nice to be back and seeing what everyone has been up to.
