Mikemo
Greetings to all my Honda Twins friends. I was looking for a forum for the 900C but didn't find one, then I thought to look here. Hopefully the brain-trust can guide me on this repair.
The bike belongs to a friend of mine, a 1981 CB900C with 23k miles, totally stock. He bought the bike 10 years ago and only rode occasionally. He called me recently, frustrated with the bike. The rear brake locked up on a short ride and he had to get towed home. Then, he couldn't find a shop to work on the bike. Even the local Honda dealer said it was too old for them to touch. He was ready to junk it, but I told him that I'd have a look.
The rear brake was an easy fix. I rebuilt the master and caliper without any issues. It was on my test drive that I really noticed the issues. Just starting it was a chore. You have to pump the throttle to prime it with the accelerator pump just to get it to start. It would idle once warmed a bit, but the bike ran like garbage. Terrible throttle response, low power, etc. I was thinking that the carburetors needed to be cleaned/adjusted. A quick compression test showed differently, with 150psi on cylinders 1 through 3, but only 50psi on cylinder 4. A valve clearance check showed everything fine except one of the exhaust valves on cylinder 4 that had zero clearance. A leakdown test showed major leakage out of the exhaust on cylinder 4.
Getting the engine out of the bike was a pain! That thing is massive. You have to disassemble everything to get it out (rear tire, drive shaft, swing arm). Here's a picture of the valves on #4. The valve is toast, but the seat doesn't look melted. I ordered a new valve (Vesrah) and will lap it and see how the seat looks. I'm hoping I don't need any machine work done.
So finally to my questions. I'm trying to keep the cost down, but don't want to ever have to pull this engine out again. Head gaskets are no longer available from Honda, but can be had at a dear price of over $100 from csml or David Silver Spares. Can I get away with an aftermarket gasket set? Any suggestions for a source of aftermarket gaskets? If I can get away with it, I don't want to touch the other 15 valves. Is this a mistake? Should I completely disassemble the head and get all the valve seats cut?
Thanks for reading. I hope this wasn't too long and boring.
Mike M.
Mike M.
