This is an excellent assembly pictorial from another forum, you can use it in reverse for now and to assemble later
Yes, chrome ring would be topCertainly is odd. Chrome ring on top, I'd assume.
I'll have to tune the carbs soon, do you guys have some advice on how to do this? Should I purchase a set of vacuum gauges?
Awesome thanks! I'm having a little trouble with the head gasket and oil galley o rings. I put the 3 dowels in first, then the two o rings on. The head gasket has two holes that are clearly bigger (indicating the proper orientation), but I can't fit those over the o-rings by hand. Should I cut it out a little, or just put the head on and assume the compression from the bolts will do the trick?
