Greybeard70
My bike runs great except after I replaced the paper part of the OEM Air Cleaner with a free flowing foam it runs lean on high speed. It will easily get up to 80 mph and no faster. There was still quite a bit of throttle left which indicates it is running lean at full throttle. I then installed a larger main jet, 145 replaced with 150. Now it will easily reach 90 mph, problem now is that it seems to be too rich in the midrange causing it to have an intermittent miss at part throttle. Consistently intermittent in mid range operation. Idle is perfect , wide open is perfect. On any other carburetor I would raise the clip on the needle, dropping the needle so it will run leaner in the midrange. There is no clip on the needle with this carburetor. Are there any needles available with the clip option?
I have a spare set of needles from a rebuild kit and am considering removing a slight bit from the top of the retaining bushing to allow the needle to drop down slightly and try that. Any input from you knowledgeable guys would be appreciated.
I am pretty sure the mid range is running rich as it doesn't miss when the engine is not warmed up, but after riding a few minutes and it heats up it does exibit the issue.
I realized this is posted in the wrong forum would one of the moderators please place it in the 450 forum.
