guattereuze
Hi everyone,
I'm hoping all you wiser and more experienced folks can double check my troubleshooting and confirm my diagnosis. Edit: I did consult a number of posts in this thread list, but just wanted to make sure I was on the right track.
So, I brought back my 74 CB360 from the shop last week. It had been there far too long, and I will partially expand upon the laundry list of "fixes" they did. After driving about 35kms on a warmer than usual day, I parked outside the house and went inside for dinner; when I came back out to ride around some more, I couldn't kick start the bike--only got the kick start anyway. As one would expect, I was very disappointed and I vow to never give another cent to that mechanic again.
Anyway, I start troubleshooting and the most obvious culprit is the lack of spark from both plugs when checking them against the fins. I have a new battery and new ignition coils, but I charged the battery up just to be sure. I make sure the kill switch is off, and still, no sparks when I kick it. The points also have no sparks, but when I check with the multimeter, the points, ignition coils, and the wire/boots all read 12.3ish volts when the ignition is off--11ish volts with ignition on.
I ordered a new condenser to cover my bases, but to my limited knowledge the lack of spark and the positive voltage point towards something going on with the kill switch wiring and/or function, right? The mechanics did a day's worth of wiring work and mentioned they had some issues with starting it because of a short/connection issue, so that's another clue.
One weird thing I did notice was that when the ignition was on and I switched the kill switch on and off, sometimes the right plug would give a little spark... As though it were mocking me--the nerve!
All that said, your collective input and double check would be much appreciated!
Thanks
Guatt
Thanks
Guatt
