tomeben
Once the overflow line is connected, I think I'm ready to see if this thing will actually start. Here's hoping.
Looks really good, I like the mufflers. Here’s hoping x2!
They look good on the bike. Just like they belong there.My solution to make the aftermarket mufflers fit the headers was to use the adhesive aluminum tape I mentioned...
Yesterday I tried starting the bike for the first time with mixed success. It did run, but only if I held the throttle open.
I also discovered that the kick starter lever doesn't clear the aftermarket mufflers I installed.
Thanks, I found something that I think will work starting with searching the one you bought.
https://tboltusa.com/store/kick-start-lever-br-curved-crf-type-14mm-shaft-p-1990.html
Now I need to work out why I haven't been able to get it to idle. The jets are the correct sizes now and I adjusted the float heights per the shop manual. Maybe I have the needles clipped at the wrong level? I would think that it should idle with the carb throttle slides all the way down and the idle screws back out all the way but maybe that's wrong? And how do the air screws effect idle if at all? I'll have to do some more research and fiddling around.
Probably a lot of little issues here and there but I'm happy to say the engine runs, idles, and shifts at least into first gear and out without an issue.
Too bad you don't have the centerstand on the bike, you could shift it through all the gears with it running sitting still. As for the sidecovers, when I look at the later CB175 covers at RetroCB the top tabs seem to be about the same width as the earlier ones, and it wouldn't surprise me if Honda kept the mounts on the frame in the same spots over the years and simply changed the design/style of the covers. Richard Pitman would probably know, he knows 175s very well.
