jensen
Like mentioned earlier, although I'll switch to E-ignition, I also want a complete functional / original points ignition as a backup. So, the next step in the wiring harness preparation is mounting of the condensers. The CB72 has the condensers mounted underneath the right coil bracket, a much better and accessible place then the awkward choice of Honda engineers placing the condensers on top of the engine, like the C77 dream.
But before I could mount the condensers, I had to locate the, yellow plated, 5mm JIS screws. Luckily I worked 7 years for a Japanese company, so getting the right JIS hardware wasn't so difficult.
Locating the little screws took longer then mounting the condensers and putting the bracket back to the frame.
The wires of the condensers are cut, so I have to add new bullet connectors. I think I have to order a bunch of bullet connectors anyway, because my stash dried up lately (CD50H, CB400F, SS50Z K3).
I was a little fed-up with the electrics (not my hobby), so I went to some mechanical work, in this case mounting the rear fork.
While disassemble the rear fork for painting preparation, I managed to push out the rear fork bushings in one piece, just like the collars. After measurement, of bushings and collars, I decided to replace only 2 bushings (out of four), and only one collar. I did use the new parts on the right side (chain side) and the best 2 out of four bushes and the best collar out of the two on the left side. All bushings and collars where within spec (no radial play) but the surface of one of the collars was a little scored.
Luckily I didn't had to buy them, I had both items them in stock.
Two old bushes and the scored collar are going back into my stock for the next CB72, both are within spec, but I like to use them on the left side (not the chain side).
I don't know what the prices are today, but the total repair was only 6 euro's for the bushings, and 4 euro for the collar.
Nice and tidy, I pressed the bushes in with a vice, not ideal, but it works. In the close-up one can see that the paint job is kind of rough, that's because the paint is sprayed directly over the bare metal, no fillers, no epoxy under-layer. It's a industrial paint, specially designed for this kind of work. It's not going to be a show bike anyway, so I'm happy with it (and the price was good too). Like mentioned earlier, I only painted the parts that aren't directly in sight, so fuel-tank, headlight ears, headlight shell, front fork covers will stay as they are, being original paint with a little patina.
I also found NOS rubbers (mounted on the insight of the fork bearings), and a nicely, plated nut and shaft completing the picture.
Not much to tell, but just a nice picture. I really like the setup with the aluminium parts.
And the other side as well.
After assembly I greased the bearings via the grease nipple's on both sides of the rear fork axle until the grease was visible on the outside of both bearings. The movement up and down of the rear fork is nice and smooth, absolutely no radial play, and certainly no axial play as well.
I know that many people replace those bushings by bronze ones, but I decided to use the "plastic" bushings from Honda. Regular maintenance (once a year using the little grease gun) is the key.
The grease nipple's Honda uses on there early bikes are sometimes hard to reach with modern grease guns, especially the one at the left side. I use this special, old handy small grease gun I got with the CB400F. I'm grateful that the PO of the CB400F thought about these little things. This grease gun is leak-free (you can close it off), and is small enough to stash it in the bike's tool tray.
As you can see, the grease gun is heavily used, the black coating on the outside is almost worn down to bare metal.
Next job is the wiring to the tail light, head light and winkers, adding a battery and battery clamp so I can find a place for all the extra electronics (E-ignition, headlight relay's and the reg/ rec unit).
