MrMoonbeam72
Yes, both floats were (re)setWhen you cleaned the carbs, did you also set the float height level?
While certainly not impossible, tach drive seal leaks are less common on the DOHC 450 for whatever reason.The tach drive seal... ...can also leak
For the instrument lights power for the bulbs enters and exits through the 2 wires and the bulb holders are insulated from vibration by the rubber mounts so not grounded there. Due to the age of the holders there may be corrosion on the center pin and around the metal shell of the holder. The spring that holds pressure on the center contact may be collapsed and not applying enough pressure. I would pull them one by one and inspect the holder for any issues. Also the problem could be on the connector end of the wires inside the headlight bucket. The bullet connectors could be loose or corroded and when you push the holder it moves the wire enough to make contact there. The wiring diagram in the FSM is usable but if you can find a color diagram somewhere it makes it a lot easier to read. I have a color copy for the K5 which should be very close to your K3 and I would be happy to send to you if you like. Just PM me.Can anyone define how those are supposed to be connected in and grounded? Both the left most and middle in this picture were hanging down, and both have electrical tape to make them fit in the holes better.
Do I have too much tape on them perhaps? The rubber plugs arent working any more to hold them in
Sounds like you're telling me even if these were dangling everywhere, the issue is either on the bulb and socket end, or the other end to wherever they lead to. Nothing to do with how they are pushed in or mounted - i'll dive inFor the instrument lights power for the bulbs enters and exits through the 2 wires and the bulb holders are insulated from vibration by the rubber mounts so not grounded there. Due to the age of the holders there may be corrosion on the center pin and around the metal shell of the holder. The spring that holds pressure on the center contact may be collapsed and not applying enough pressure. I would pull them one by one and inspect the holder for any issues. Also the problem could be on the connector end of the wires inside the headlight bucket. The bullet connectors could be loose or corroded and when you push the holder it moves the wire enough to make contact there. The wiring diagram in the FSM is usable but if you can find a color diagram somewhere it makes it a lot easier to read. I have a color copy for the K5 which should be very close to your K3 and I would be happy to send to you if you like. Just PM me.
The top end/head has not been touched. I'll take a look at the tach seal, but I would tend to think I would see this surrounding the cable fitting as wellThe plug is a little dark, but I don't think it's a proven the way it is.
The fins on the head appear dry, so that oil may be coming out from the head gasket. The wind blowing over the motor trends to push pull from the front to the sides, so it doesn't necessarily leak where you see the oil after a ride. The tach drive seal and sometimes the header gaskets can also leak depending on what's going on.
Did you rebuild the top end? Can't remember offhand, but if yes did you ever re-torque the head?
Correctly interpreted from what Rob said. The rubber boots on the sockets are just to hold them in the gauges, nothing to do with insulation.Sounds like you're telling me even if these were dangling everywhere, the issue is either on the bulb and socket end, or the other end to wherever they lead to. Nothing to do with how they are pushed in or mounted - i'll dive in![]()
If it's the head gasket, and it very well could be, retorquing it is unlikely to stop the leak but it's worth a try. The seepage generally comes from these areas of the head gasket when it's leaking, and these are the areas I always use a little sealant on.The top end/head has not been touched. I'll take a look at the tach seal, but I would tend to think I would see this surrounding the cable fitting as well
