hoffdahobo
Hello!
I've been working on a 1970 CB350 that is my father-in-laws. He told me that he got some head work done previously and that he is suspecting that it was done incorrectly. I validate this by trying to install the head and having zero valve clearance, couldn't get the side covers on with the valves in place. So I send the head off to be reworked and finally have it back. Installed the cam gear and cam which is the skinny cam and tried to install the rocker arms and pins in and now there is another issue. The covers go on smooth when its just the rocker arm pins and cam but to get the covers to slide on with the rocker arms in place i have to set the pins to be facing up (the little tick mark faces up). I can then successfully put the covers on easily but have almost no valve adjustment. I'm assuming that the shop I sent the head out to did the job correctly but I'm beginning to get really frustrated with this whole thing. The rocker arms have .8 marked on them and no other visual indicator. All these parts came out of the engine and was in the engine when it ran (almost 20 years ago) so unless he mixed and matched stuff i'm assuming everything is correct. I have put the left cylinder at TDC as well with both valves closed per the book and i can move the intake pins a very very small amount and the exhaust pins move but with some force. None of the valves are loose enough to make a ticking noise when trying to adjust. I can attach pictures of the valves/pins/cam/and cam gear if needed to help out. Thanks!
Other side note: The engine does turn over fairly easily when the rocker arms are in with the two side covers attached. No binding
