rapid_roy
Hey all! I'm trying to get this ’72 CB175 in reliable, safe running condition.
I'm a motorcycle noob still, so thank you all in advance for sharing your wealth of knowledge and experience!
A bit of history. I bought this in Feb 2018 from the second owner, who had kept it garaged since the 80's. It did start when I bought it.
After that, it sat at my Dad's house for a few years. He had someone replace the rust-eaten mufflers, new clutch cable, new tires, and allegedly something with the brakes. Changed the spark plugs. The mechanic wasn’t familiar with vintage bikes (the mufflers they got blocked the kick start), so I’m not sure the work was well-done.
It was ridden a few times there by my dad. I picked it up in March 2021 and brought it to my house. The petcock had been left on, and it wouldn't start, so I took off the carbs and gave them a full cleaning, replaced float bowl gaskets.
Other work I did:
-new AGM battery
-changed oil with Shell Rotella T4
-cleaned gas tank rust with EvapoRust
-new petcock
-new kick start lever that clears mufflers (but I haven’t gotten it to start w kick)
-new fuel lines
-new gas cap gasket
I finally started it up in September 2021, and rode it around the block for 10-15 min. I think it stalled out when I came to a complete stop in 1st, and tried releasing the clutch. After doing that a few times, I couldn’t get it to start again. Maybe the battery was done?
Fast forward a year later, I moved again (Jersey City) and finally have time to get it working.
I got it to start a few weeks ago, and rode it around the neighborhood for about 15 minutes. I got it up to 3rd gear.
But problems arose when, again, coming to a stop and letting the clutch out in 1st gear. It kept stalling. It seems like the clutch lever was sticking, ie it wouldn’t release when I let go. The power was not engaging. It stalled about 4-5 times, and I couldn’t get it to start the last time.
Also, the gear shifter seems to get stuck. A lot of force is required to kick from 1st to neutral to second.
Last week I tried starting it again. Video below. I couldn’t get it to idle. I’m applying very little throttle, but the RPMs rev very high, then it dies.
https://youtube.com/shorts/eU7e3L8k8r4?feature=share
https://youtube.com/shorts/f46w29F_F-Y?feature=share
Someone told me I might have to take apart the clutch, and clean the clutch plates or get new ones. That should fix the clutch sticking/stalling issues. Since it was sitting for so long. But I’m not sure about the high RPM issues it’s having with starting now. What do y’all think? Thanks!
Other work I did:
-new AGM battery
-new petcock
-new fuel lines
-new gas cap gasket
