NeverEverJamToday
Rebuilding the cb200 rebuild. Lean out from corrosion debris that kept developing in just one sides float bowl clogged jet, burned hole. Definitely due to ethanol presence. Learning too much about that, and not enough.
Been looking into coatings so this doesn't happen again. Looking more and more like an hdpe lining (powder coat? ) might be the best option. Contacted keihin about the exact alloy these carbs were made of to try to determine options. While i received a quick response, the info available regarding materials used by keihin Japan at the time is officially "whatever was available".
So far I've tried bonderite at an attempt to alodine the bowl, unsuccessful. Tried baking vht chemical resistant enamel. Began to soften after a week submerged in fuel.
Considered por-15,but that is stated to be flexible, so not sure if it's suitable for a bowl, with all the exposed edges. 3m products i have seen specifically advise against use with gasohol. Electroplating? Brazing with silver solder?
Contacted edelbrock, their solution is fuel additives, which i'd like to avoid.
I haven't seen a solution to this besides additives on any forum. Fuel tanks yes, but not bowls.
Sent from my SM-J320P using Tapatalk
