Very good observation on the bearing lacking the groove. I just ordered this https://www.ebay.com/itm/335036026306 and in the ad pictures you can see grooves in the bearingsI'm guessing those knock pins got waffled out because the set rings for the ball bearings on the other end of the shafts weren't there, evidenced by the ball bearing moving in the case in your video. Curiously, the outer race of the ball bearing on the shaft you're moving doesn't appear to have the groove in it for the set ring.
Yep, set ring grooves in both ball bearing outers in those shafts. I suspect someone replaced the countershaft bearing without realizing the groove was important.Very good observation on the bearing lacking the groove. I just ordered this https://www.ebay.com/itm/335036026306 and in the ad pictures you can see grooves in the bearings
To answer your question requires a question: do you have a 20 ton press? Because the crankshafts are pressed together and it takes a 20 ton press to get them apart and back together again (and you still have to know how to do it right). Typically those of us with older Hondas and pressed-together cranks look for a good used one.how hard would it be to install these
I posses a 12 ton press and am thinking about doing it but I probably shouldn't haha....To answer your question requires a question: do you have a 20 ton press? Because the crankshafts are pressed together and it takes a 20 ton press to get them apart and back together again (and you still have to know how to do it right). Typically those of us with older Hondas and pressed-together cranks look for a good used one.
There is a member here who could do the repair for you, but he's in the UK and the shipping would likely be prohibitive.
Oh my goodness is it fun to discover problems that (for in my case) have been problems since before I was born! I hear you on everything you say another ebay crank would definitely be a gamble to say the least I'm still pondering the meaning of life at this moment ha!Knock pins were wrong ones and wrong places on mine too. One, or more are hollow for oil flow as well. Check them carefully, also their length. Also check parts list for missing thrust washers on that tranny shaft. Looks like a lot of end play slop.
That crank looks rough. Sludge traps and internal drillings may be plugged. Poor oiling signs are the worn rings. small end piston pin bores and also rod side play. Hard to find a shop with big press to disassemble crank and clear drillings, replace rods, but maybe you can find one. Splash feed oiling totally depends on open crank drillings, not sump, it is below rod swing. Another used crank is just a gamble. Rebuilt motor with a plugged crank won't last near as long. Flushing crank from centers out may or may not work and is tedious.
Aren't 60 year old bikes fun, when you get to fix all previous builder's screw ups?
Ah, it's just a little flingCheating on the 160 lol
