brianwilsonsdog
Just put a new battery in today and to my surprise the headlights, neutral light, turn signals, horn and starter are all working. No blink on the right front turn signal and no light on the left rear but otherwise not too bad.
Awesome thanks guys. I'll be cleaning the carbs out tomorrow hopefully and then tackling the throttle, clutch and brake cables after that. The throttle is totally stuck and barely pulls the cables and all three cables are decrepit to the point of needing replacement.That choke connector doesn’t look very bent, so it will probably still hook up ok. It is necessary, because it synchronizes the choke plate positions and keeps both in place when open. Without it, the right hand carb plate is free to seek its own position the entire time the engine is running. The connector should look something like this, but it will work ok when bent as long as it isn’t twisted.View attachment 55525
Well part of me wants you to set up multiple cameras and record while you fill the cylinders with starter fluid and crank the engine over and have a live feed to whatever tube you want cause I figure two things will happen .... you won't have a bike to restore and you will get lots of hits and memes ......I checked for spark a few weeks ago and looks like all I needed was new spark plugs because I was able to get it sparking. Didn't actually get the engine running just yet. Points need to be cleaned and adjusted but that's a problem for another day. I also got the gas tank off and it's looking pretty alright. I took the exhaust and the carbs off today. Only thing is there's a metal strip that connects the two carbs and I sort of bent that **** out of shape. I'm not sure what shape it's supposed to be or whether I should replace it so open to suggestions. On the plus side no parts of the exhaust seem to be rusted through.
Also one question since I'm not mechanitician I can still try to get the thing to start even without carbs and fuel tank right? Like I just need to spray the engine full of that starter fluid stuff right?
I can hear your condescension and I think your answer is really obnoxious. There was a point in time where you didn't know everything yourself and had to ask stupid questions. Leave that bs unc talk in the 20th century where it belongs.Well part of me wants you to set up multiple cameras and record while you fill the cylinders with starter fluid and crank the engine over and have a live feed to whatever tube you want cause I figure two things will happen .... you won't have a bike to restore and you will get lots of hits and memes ......
So then my shop teacher brain cells kick in and will tell you in no uncertain terms not to do this. Can you hear my teacher voice? Good. Now go clean those carbs and don't play with starter fluid .... it will mess up lots of things ....
I'll give that a shot thank you. If it's warm out today I might be able to get enough work done to get it running."Like I just need to spray the engine full of that starter fluid stuff right?"
Nope, that's a good way to ruin something. I use gasolene, in an old squirt bottle, for priming engines. Better yet, some 2cycle oil/gas mix, to help the rings out with that first dry startup.
lol thank you for clarifying that. I thought something else was wrong with it. For the valve adjustment cam you're talking about those bolts with the little notch in them right?I think that noise is because you are turning over the engine without the carbs on, and I suspect without the exhaust pipes.
I also noticed that the eccentric valve adjustment cam looks to be oriented with the tick mark facing inward, it should face outward.
Nice find on the tools!
That is correct. Facing inward moves the tip of the rocker off the center of the valve stem.lol thank you for clarifying that. I thought something else was wrong with it. For the valve adjustment cam you're talking about those bolts with the little notch in them right?
which is bad rightFacing inward moves the tip of the rocker off the center of the valve stem.
Yeah unfortunately a different idiot other than myself must have roughed up those covers. I ordered some replacements that should be here this weekend. I do have the factory service manual. I'm planning on going over the valves, cam chain and working on the points this weekend. Unfortunately a bunch of basic maintenance items are locked behind screws that previous owner seems to have stripped so I'm going to be replacing them with allen bolts. I was also wondering though about the starter clutch, how can I fix the slipping issue? Should I just get a rebuild kit?Correct, not good. Do you have the Factory Service Manual (FSM) if not ask one of the admins for a copy from our library. I would adjust the valves and cam chain tension as part of your first steps to getting this bike running.
That closed end wrench in your toolkit should be used to remove the tappet covers, although they seem pretty chewed up and the wrench may no longer fit.
Thanks so muchI would wait until you have the starter clutch apart to see what the issue is. It may be more that the rollers, springs and caps. Sometimes the screws work loose and the the clutch housing becomes worn.
It isn't always as convenient, but with these old engines it's best to wait until things are disassembled before ordering parts because you just never know how the prior work was done and what additional *ahem* challenges you might be facing courtesy a PO.how can I fix the slipping issue? Should I just get a rebuild kit?
I did go over the carbs pretty hardcore although not with a magnifying glass. Should I go ahead and take the misbehaving carb off and take it apart again you think?I might have missed it in scanning previous posts but did you perform a comprehensive cleaning of the carbs? That is to say, removal of the jets (especially slow jet) and confirm no obstructions with a magnifying glass (a loupe) and strong light? Especially since one carb seems unresponsive to your changes.
If you have that bike idling, lift the throttle arm on the left carburetor. If it's running on that cylinder you should be able to feel a big change in the exhaust pressure and hear the motor speed pick up. Try it on the right. You know the right is running, so if there's a big difference it points to something in that left carb (because you have spark). If it's not behaving, yes, I would clean it again.The left cylinder doesn't seem to really respond nearly as much to changing around inputs on the carburetor. I'm pretty sure it is running. I tested for compression, spark and I can also feel the air pumping out the tailpipe.
I recently purchased used gauges on eBay and they were really sluggish to respond to input. I took them apart and cleaned old grease off the bell shaped part inside. This got them going, but the downside is that the chrome crimp ring will never look the same. You can try to protect it with tape and work on the bottom facing side, but it's hard to do without causing a little cosmetic damage.To top it all off my tach doesn't work so I'm trying to do this by ear. I tried rehabbing the cable but I think it's shot so another one is in the mail. I know the little thing it plugs into is turning so I should be getting some kind of reading. What should I do?
I gave the air filter on the left side a little spritz of starter fluid just to see what would happen and it responded strongly, rpms jumped for a bit. idk what that means but maybe that helps narrow it down.
No gas in the bowl is the next clue. Did you check the inlet pipe and spray through there? It wouldn't hurt to remove the float needle to clean it and the seat. Check the supply from the tank as well.Lol i meant the left side. Yeah both have been cleaned and the left side got cleaned twice. there was no gas in the float bowl which I thought was peculiar. I checked the float height which seems to be in spec. I thought maybe it was the way I routed my fuel line so I tried routing it differently but tbh this way doesn't look right either.
YepI did go over the carbs pretty hardcore although not with a magnifying glass. Should I go ahead and take the misbehaving carb off and take it apart again you think?
Remember that on the bike, the float needle must be pushed up to close the fuel inlet. The float rises with the fuel level until that tang lifts the float needle into the needle seat.Alright so I just double checked that there is nothing impeding the flow of gas into the bowl and yet it remains completely dry. Am I correct in assuming the issue is likely either with the floats or the float needle? Gravity should be filling the bowl until the tab on the float presses down on the needle and shuts off the flow right?
It could definitely be sticking closed. Did you set the float height on each carburetor? To what value?I want to add this, the float needle is sort of wimpy feeling/doesn't spring back well. It is easily depressed by the weight of the float tab and I think it might be getting stuck.
I want to add this, the float needle is sort of wimpy feeling/doesn't spring back well. It is easily depressed by the weight of the float tab and I think it might be getting stuck. Could that be the cause of the issue?
