Seized Clutch
Wagonwheels
UK
A bike that is stored for some time (owner probably servicing carbs, replacing broken pieces or fiddling with spark plugs) will inevitably have a seized clutch.
Its what they do.
So apparently the solution is strip down clutch. remove all the plates, throw the lot into the bin and buy new ones, preferably genuine Honda pieces if you can find them. while there, probably good idea to replace springs just to be sure.
However :cool: there might be a secret liquid that when used instead of oil will release stuck plates like magic without stripping down . Then replace the oil and the clutch works like it should.o_O not a Honda NOS part in sight.
It is a dream I have :rolleyes:
All suggestions gratefully received.
Many Thanks
My trick is to hold the clutch lever in while the engine is idling during warmup (my DOHC 450 has to be warmed up at least 1 to 2 full minutes to ensure full oil flow to the expensive top end parts). I alternate between holding the lever in and pulling/releasing the lever a few times while waiting during warmup, and by the time I go to put it into first gear for the first time in a month or so, it is usually freed up by then. If not, the worst thing that happens is it stalls the engine (fingers on the front brake lever just in case), so I restart it and the next time it goes into gear normally.
I have never taken a stuck clutch apart to free the plates. You can also put the bike in second or third gear, engine off, and hold the clutch lever in while rocking the bike forward and backward, and that will often be enough to release the oil suction on the plates.
Ditto to AD’s experience. Warm oil goes a long way to loosening those up.
My bike has been stored for about 8 months, maybe more, until this week. Clutch was not stuck. That said, I might consider clamping the lever in the released position if it appears it will be longer. I know the springs won't like it, but as long as it fully engages, it's all good.
In my experience, removing the clutch plates and cleaning them with brake cleaner, will remove most of the goo causing the sticking problem. Then reassemble in reverse order of disassembly.
Also, back in my dirt bike days (mid 70's) if they were slipping, we would lightly sand the surface of the plates with whatever sandpaper was on hand to remove any gloss and then flipping the plates over from the way they were originally installed.
OR - You can just remove the side cover and spray brake cleaner on the clutch while pulling the lever in, to open gaps in the contact surface. Some would probably say to coat them with oil after cleaning, but since they run in an oil bath I don't really think it is necessary.
I have released stuck plates before, in gear, clutch lever in and hey presto! I can stop the rear wheel with my boot, release clutch and it spins, clutch in + boot and the wheel stops spinning...
However this time I don't get the same result, engine labours and stalls:(
OK so if at first you don't succeed ...........:rolleyes:
Many Thanks for your contributions.
On project bikes I pull the plates, clean the steels and then soak the fiber disks in oil for a day before reassembly. (Even when they are not stuck). Problem with freeing up a stuck and mostly dry clutch is that you can really blue up the steel until the fiber disks get some oil on them.
Last time I freed a stuck clutch I put the bike on the center stand, started her up and used first gear the rear brake and exercised the clutch for a few minutes until all was working well.
Mike's mention of using the kickstarter to loosen the clutch is also a good one, works on all but the SL350K1/K2 and XL250/350 from that era (those have primary kickstart).
What I have done with my Dream, and I am not sure if this is a good thing to do. My garage is on a hill and I live on a dead-end road with a cul-de-sac, so with the bike running and clutch pulled in, I get it rolling down hill at a good pace click it into first gear and ride slowly and work the clutch and throttle. It freed up for me. However when sitting it would like to stick again. But now after many heat cycles and oil changes I have not had a problem in two years. The bike had sat for seven years. Before even attempting to ride it, I had got it running and warmed it up and changed the oil multiple time.
Many Thanks for your help, seems my Summer runabout has other ideas.
The boot technique failed as did the the rear brake technique, try too hard and the engine stalls. Rocking the bike in high gear didn't work either..... :(
Looks as though the clutch cover is coming off :rolleyes: .......again! friction/steel plates availability?
Many Thanks
Many Thanks
So you're saying that holding the clutch lever in while trying to kickstart the engine doesn't break the clutch loose?
Pilgrim's Progress?
Yes I am, except I don’t have a kickstart, still, bike on centre-stand, clutch lever in, start bike, drop into first and the rear wheel spins, apply rear brake, loads engine, apply throttle, lean on rear brake, engine stalls....
I have removed the clutch cover (oil was very black, which was surprising), removed springs, clutch plates separated easily:unsure:
Ordered a clutch lock nut tab washer++. My bike's clutch lock nut doesn’t seem to have one:unsure: but the castellations have been smacked with something? perhaps that is why the tab washer was the only Honda
original part I could find!
As always many thanks for your advice.
Happy Fathers Day!
I've always used second gear or top gear.
First try is to roll bike BACKWARDS at walking pace and flick lever into second. (with clutch lever pulled in)
The momentum of bike will push a lot harder than you can on your own and weight trying to lift front wheel means it's very very unlikely to just slide tyre. (which always happens going forwards)
If that fails, top gear jerking backwards, torque multiplication almost always frees up clutch.
Oh, rolling backwards in gear is also the best way to find TDCC for 'push start' race bikes.
I was very surprised I had to explain it to experienced vintage racers
Thank you for your contribution, useful to know!
Now, let no one say I don't use genuine Honda parts.....
So I buy a clutch centre nut removal tool (not a Honda one) still four 'prongs' to remove a castellated nut what could go wrong?
Unfortunately the tool don't fit the nut :mad: the nut seems to be too big? :)
Have the supplier sent what they described? answer yes...well sort off. distance between 'prongs' (there are four of them) is 2.39 cm (using my electronic digital callipers, zeroed before measuring) advertised distance 2.4 cm.
Have I got a strange oversize nut holding my clutch together? or should the prong distance be more than 2.4cm......maybe.
So
Would some kind person who has used such a tool, Honda or otherwise, tell me what the distance between the tool's 'prongs' should be before I start grinding 'prongs'.
Many Thanks
P.S. Anyone know the number of the Honda tool?
So
Many Thanks
This would appear to be the one, and it would appear to be in the UK
Since your thread evolved from a "Tip or Trick" for the stuck clutch plates to you working on the clutch, I moved your thread to the SOHC Engine section.
Also, I looked through many of your threads and your profile as well, can't find anywhere that you mentioned the year of the bike.
It's a 1981 according to this post...
Guess I missed that one.
Pilgrims Progress (sort of?)
Many Thanks for your help.
Think an apology might be in order from me. Think it was pure frustration on my part.
I measured the distance between the slots in the clutch nut, a couple of millimetres larger than my prongs. I obviously bought the wrong bit, (thanks for the link to a proper tool) so I ground the prongs down (no lathe here just my angle grinder).
It fits, happy days! Next problem is to lock up the gearbox so I can remove the nut, it seems a tad tight......and no tab washer.....heat?
Many Thanks
Many Thanks
Without a picture of an engine I'm less than familiar with, many here use a copper penny in between the primary gears.
Did you, by any chance, order this tool from the outfit in Houston? Because I’ve had some similar experiences with wrenches for tappets and spokes. In my case, a little filing made them useable. Is yours close to the right size or way off?
EDIT: Missed your post about grinding the tool. Glad you got it worked out.
