Too large for the mixture screw. Fuel crossover tubes?Actually, it might belong to the mixture screw. I don’t recall it and the number is wrong in Clymer. I’ll check tomorrow when back in the shed.
The O-ring seats against the carb body, the washer squishes the O-ring to seal on the screw. The way you have it the threads will just cut into the O-ring ruining it.I was just testing you….The way I have it, wouldn’t that also stop fuel or air entering via the threads?
Also, if o ring goes in first, that would be a pain to remove. Maybe the spare o ring was blown out from there…
Yes, it is. I straighten out a paperclip, bend tip 90 degrees then cut it off about 0.5mm long and file 'squashed' end where wire cutters crushed it.Also, if o ring goes in first, that would be a pain to remove. Maybe the spare o ring was blown out from there…
