asdfqwer426
I have three kinds of honda keys here. I know the codes are just so you can buy pre-cut keys, which I love, but for bikes with damaged or missing locks I would like to write up a guide to rekeying the existing locks.
I'm curious if the first digit might be indicating where the key groove is or something? is there any more info out there on this kind of stuff? I haven't quite started looking at pictures of keys to match up characteristics, but that's probably what I'll be doing soon.
A few years back I couldn't get my 350 key in the ignition and upon closer inspection I found the pin was able to fall too far down into the keyway and jam in there. It's hard to see in this picture, but you can kind of see the pin in T4546 is lower than T3796 next to it.
Using a small flat head, I can push it back up enough to get the key in, but it's been an issue. When my electrical switch also went out I completely tore it down including pulling the pins out and concluded that the lock cylinder was just damaged. I cleaned up the switch and put it back together with the intention of finding a lock with a similar keyway to swap cylinders and pins. I plan to do that right after this post and make pictures so I can write up a guide. Although the 4 key and 3 key have slightly different keyways, the 4 key seems to fit in the 3 and vice versa , so it should work for me.
I also have a 360 without a seat latch. I would like to buy a seat latch with a matching keyway and repin it to match my ignition key, and probably do a write up on that too when I get to it. I need to measure the lock pins inside the ignition switch first, and find out which seat latches have a matching keyway - hence my first question here.
Hope this fits the "technical" header!
EDIT:
After searching, it does seem like the first number indicates where on the key the side cut is, with 1, 2, 3, and 4 on the left side of the key, and 6, 7 and 9, on the right side of the key. groove 1 mirrors 6, 7 mirrors 2, and 9 mirrors 4. I have yet to see pictures of a 5, or 8 key but if the system matches up, the 8 key would mirror the groove location of the 3 key.
