How do I remove sprocket CM400A
Windmill John
East Sussex, England
Okay, there’s no circlip and Clymer says tap through from other side of wheel.
I’m doing this. My taps have changed to TAPS. Before I increase my percussive maintenance, am I missing something?
Thanks.
There is a C clip behind that rubber dust seal, that holds the sprocket on the rim.
Also Part number 3, is a shim washer, it can become worn, this will let the sprocket move/rock too much in and out, so if the sprocket assembly is loose replace it.
my CB400N uses the same parts and have pulled the C clip groove of both my rims, so it needs to be tight.
If you are replacing the sprocket with a non oem sprocket you may need the spacer that is press fit into the sprocket.
Hi beans, thanks for the input. Mine is a 1981 A. Even though I mention that, CMSL shows a circlip, but I cannot see one. If mine had been left out, there still should be a groove; there isn’t one.
What am I not seeing?
Too far down the rabbit hole. It’s back up here.
The wheel bearings do tap out from the other side. Pretty hefty taps.
Curiouser and curiouser said Alice 😉
Thanks EzPete, I’ll check in the morning, cat on lap, can’t move….
Wish I hadn’t removed the dust seal that was covering the bearings… buggered it, new one ordered.
Thanks for mentioning this Beans. I saw the new sprocket moved sideways when offering it up. I’m sure I wouldn’t have thrown away the old assembly without checking, but you never know! I possibly did offer up the new sprocket following your comment though!
What an obvious big circlip when you remove the right dust cover 🙄
Dont forget the spacer thats a pressed fit I to the sprocket if youre changing them. Ive seen people replace them without this and its incredibly unsafe.
Thanks Maraakate, that’s what Bear had mentioned. I offered up the new sprocket and the sideways movement was obvious. You’d be relying on the cush rubbers for movement in all directions! I could easily see a nightmare situation if left unnoticed.
I did notice my replacement sprocket is 36 teeth and not 35 like the original. Cor, the acceleration increase, I’m going to struggle keeping the front wheel down. 😉😊
If you need that spacer, DSS has them and I used one recently. Fit well into a JT sprocket but could be different if you are using another brand.
