That 16010-417-305 kit you photo-linked from eeeBay is incomplete and missing several O-rings and the black plastic kidney-bean shaped part installed under the slide pistons which I see you already have and should not be bought
If the rubber of your 2 air cut off diaphragms is still flexible and neither has any holes or tears, re-use them. Also re-use your large white plastic "stopper" rings unless you break one or both during cleaning.
In another of your photos above I see O-rings mistakenly put on 2 of your brass main jets (#72 or#105)...
I
strongly suggest that you spend significant time during the next week or two reading thru many of the "sticky" (permanent) threads in the SOHC sub-forum here titled Carburetion & Fuel where you'll learn a lot more of what you need to learn just like I and most others have...
the last 2 photos you shared I see are from 4into1 website which is a good source for your carbs needs
Here's an excellent source for your carbs O-rings:
This carburetor kit includes most o-rings needed to rebuild your VB carbs on your CB400/CM400/CM450/CB450SC. You can buy these individually but you'll pay minimum quantities. O-rings are not junk ones sourced from Harbor Freight kits. These are direct from McMaster-Carr and are NBR rated for...
www.hondamaticparts.com
