stl360+450
I think mine were developing cracks in the same area. I wonder if it's just fatigue from banging into the underside of the carb body over and over.
No, open the points gap slightly, causes the rubbing block of the points to contact the lobe sooner.I had a chance to try out the cutout timing cover that @VintageHondaGarage made and works great. Stopped the oil dribble that was coming out even with the bike leaned slightly the right. I will post some videos later but I was pleased to see that the left timing mark is spot on! The right is slightly retarded just off the F mark towards the the T mark. Question, in order to advance the timing slightly would I would need to close the right points slightly?
Yes the cover works well. The only thing is it is made for button head screws so you will need to come up with some. I used a bit of cut off fuel line to act as a spacer/washer on the screws I used.Cover looks cool and seems to work well.
I’m trying to get my hands on a 450 so that I can get the proper bolt length and include them with the covers to avoid this issue. The 350 covers I know the length of and am just waiting on the bulk order I did to come in.That worked! It was just slightly off but after just barely opening points to about 15 thousandths looks spot on as well. Also checked the advancer and it advances and retards when applying and letting off the throttle so I call it a pass as well.
You can use a site like Partzilla to get the bolt length. They usually list the size in the description. For example #20 in the pic is the alternator cover screw, 6mm X 45mm long. Oval head is the counter sunk type of screw.I’m trying to get my hands on a 450 so that I can get the proper bolt length and include them with the covers to avoid this issue. The 350 covers I know the length of and am just waiting on the bulk order I did to come in.
I’m well aware, but my cover isn’t the same dimension depth-wise as the stock cover, so I need to figure out what length will be best.You can use a site like Partzilla to get the bolt length. They usually list the size in the description. For example #20 in the pic is the alternator cover screw, 6mm X 45mm long. Oval head is the counter sunk type of screw.
drive.google.com
Really nice, that's how they're supposed to sound.Went for about a 30 mile ride earlier and other than a duhhhh moment when I found the choke was still closed about 1/2 way which will limit your Vroom Vroom, everything ran well, no weird noises or leaks. We are having intermittent showers it's back in the garage. I think the only thing left is to paint the tank and side covers. Hopefully can start on that soon.
Pre-ride video, idling nicely.
IMG_5394.MOV
drive.google.com
I think he might have just painted the stock mufflers black for now.What mufflers are those? Do they have a removable baffle? I knew you ordered headers, but was surprised to see the new mufflers. The bike sounds really good.
Final product on your bike is going to be a testament to either dedication or insanity. Starting where that thing came from to this is pretty damn impressive.Went for about a 30 mile ride earlier and other than a duhhhh moment when I found the choke was still closed about 1/2 way which will limit your Vroom Vroom, everything ran well, no weird noises or leaks. We are having intermittent showers it's back in the garage. I think the only thing left is to paint the tank and side covers. Hopefully can start on that soon.
IMG_5394.MOV
drive.google.com
They are the original mufflers, the chrome was shot and a lot of surface rust so I sanded the crap out of them and painted VHT flameproof black. I need to take it on a really long ride to see if I can get the paint to cure properly. The mufflers were "modified" by the PO with a chisel I think knocking four slits around the outlet. I didn't know how I was going to like the sound but I actually like it. I need to get the wife to take a few videos when I am riding and accelerating to hear how they sound off the bike.What mufflers are those? Do they have a removable baffle? I knew you ordered headers, but was surprised to see the new mufflers. The bike sounds really good.
Thank you and I like the primer look as well but when I have a couple of good days with no honey do's I will try my hand at rattle can painting. I am going to paint with Honda Milano Red that @Richard Pitman painted his 175 and I was really taken with the color. Hopefully will turn out close to as nice as his. As for dedication or insanity I cannot bring myself to tally up my receipts but I am sure I could have about paid cash for the new Royal Enfield 650 I was considering but i would not have had the satisfaction of this build or the pleasure of being a member of this forum.Final product on your bike is going to be a testament to either dedication or insanity. Starting where that thing came from to this is pretty damn impressive.
I’m still digging the unfinished patina of the primer.
Thanks for the link and those do look nice and I am sure would sound good. I am hoping the paint cures well and if it does I will probably run them for a while. I did break down and ordered a 1975 CB500T front fender off E-bay at a decent price and it just came in today and of course I put it on today. I will post pics later but I like the look especially better than the black and chrome one I had.My 450 came with sportster tips and they really weren't bad at all except they had been fitted to the headers using a bit of plain galvanized pipe extensions. You might be able to pick up a used set on the cheap if you're interested. The extensions would have looked cool in the flameproof black. I think they may have been 65613 tips, like these.
Thank you! I am looking forward to getting a few more confidence miles under my belt and we can meet up for a coffee run we spoke about.She looks beautiful my friend. What an accomplishment!
And of course we'll need pictures of that as well!Thank you! I am looking forward to getting a few more confidence miles under my belt and we can meet up for a coffee run we spoke about.![]()
Thanks for the compliment on the fender. My search for a nice 450 front fender wasn't going well but I found there were a number of the 500T fenders available at reasonable prices and the more I thought about it the more I liked it. The black mufflers were a stop gap measure but they are growing on me as well and as for a slimming effect you know a lady always looks great in a little black dress.The 500T fender looks great. Now that I have a better look at the black pipes I can easily recognize them as OEM. Somehow the black paint has a slimming effect that threw me off while watching the video earlier. They look good!
Of course obligatory pictures. We may have to keep a low profile though, I'm not sure the local biker crowd will be up for two 72 CB450's!And of course we'll need pictures of that as well!
It has been quite a journey so far and I have to say I am pleased with the results myself!EzPete is right, from where that bike started to where it is now has been quite the successful journey.
Funny you say that. I took my first ride on 85 the other day. After 40+ years riding at freeway speeds takes a little getting used toThank you! I am looking forward to getting a few more confidence miles under my belt and we can meet up for a coffee run we spoke about.![]()
drive.google.com
It sounds good riding away, and the play by play was well worth it!Put another 20 miles or so on it today and I would say the bike is running very well. I only noticed one hiccup and it was one I expected when I felt a loss of power but only needed to be switched to reserve and picked back up on the go. My better half took a short video of me leaving complete with commentary that I will share.![]()
Just hanging out! Had a little time before the recent cold front and pulled the tank and side covers, cleaned old primer with tar and wax remover and then re-primed with several coats of filler primer. Waiting for warmer weather again to lightly wet sand and then spray the color on them and then back to the waiting game to let that cure for a week or so and then go for clear.
Appreciate the compliment but I have to give most of the credit to the great shop teachers I had in school and supervisors in the Air Force. Also the number of times I have got in a hurry on a project and got ahead of myself and something comes undone has finally taught me to slow down.Rob, your methodical approach and patience throughout this project is very impressive! I can’t wait to see how your paint work turns out.
Post some picks of the R75 when you are done!Excellent! Sounds like you know what you're doing. Looking forward to seeing the results. I'm spraying a vintage BMW R75 tomorrow. Must be that Spring is coming!
Dude, we're gonna be twin twins on our coffee ride! Ditto on what LDR said. I have a friend who was a professional body and paint man redo my boat a long time ago. I was amazed how smooth he got the finish with wet sanding.Painted the tank and side covers the other day and I do like the color but I am concerned with how grainy the finish turned out. I am not sure if it was technique, weather or a combination of the two. I am letting it cure until next week and I will see if I can sand it out a bit and improve the finish before shooting the 2K clear. Paint and body work is like carpentry for me, a whole lot of work invested for marginal results sometimes. Helps being a dumb old country boy I don't know when to quit.
I think you're selling yourself short here. You've been doing a great job spiffing this bike up from the word go and I think you'll be surprised by how much difference wet sanding makes, especially with the color paint. Don't be worried if the color appears a little dull after wet sanding, this will instantly change when the clear is applied.Whatever I turn out with is how it is going to be for at least this summer
