Everything looks good, but I'm a little concerned about the bluing on that one shift fork - what does the side view show on the tips of the fork and the possible half-circle wear it might show that caused the discoloration?Slow progress……Head done. New valves and outer springs. Passed the leak test.
Kickshaft, shift drum, transmission along with crank back in top half of case. Bearings indexed on new knock pins…. Old ones bent.
Let me know if someone sees something terribly amiss!!
Thanks Tom. They are not bent and dit not appear to have atypical wear to my eye but I look at them more critically.Everything looks good, but I'm a little concerned about the bluing on that one shift fork - what does the side view show on the tips of the fork and the possible half-circle wear it might show that caused the discoloration?
Tom I finally got back to garage to lift transmission out to recheck the shift fork you mentioned in an above photo.If it has any scoring on it like this (exaggerated example) then it is usually bent, and they rarely get hot enough to blue unless there's a reason.
They rarely appear bent visually, but when they have any wear or light gouging on one side like shown in your first picture, it shows the fork was pushed hard one way and I try to find a replacement. I don't have the equipment to measure if it's out of spec, but since the engagement depth is sometimes only 3/16" or so every millimeter it's tweaked can help it jump out of engagement under load. Also, what at first looks like they both got hot might actually be a oil level stain? Hard to be sure from a picture though. And since (I'm assuming) you didn't ride with this engine to know if it shifted properly, it would suck to put it all together only to have to go back in there again.Tom I finally got back to garage to lift transmission out to recheck the shift fork you mentioned in an above photo.
Here are new pics. Some wear on one side but do not appear bent. Thoughts??
That's an unbelievable price, I'd jump on that before it disappears.NPN has two shift forks in stock for $11.54 each which in my opinion is a very good price. I would change both out for that price.
They are used, but look to be in good condition.That's an unbelievable price, I'd jump on that before it disappears.
I know they sell used stuff but I didn't even look at that area when I checked the link because they looked so clean and shiny, I just assumed they were new. Still a great deal and I'd buy them too if needed.They are used, but look to be in good condition.
The knock pins also keep wear on the forks down. If the trans shafts shift then the forks also wear funny.Tom I finally got back to garage to lift transmission out to recheck the shift fork you mentioned in an above photo.
Here are new pics. Some wear on one side but do not appear bent. Thoughts??View attachment 54615
Good point I had never thought about that but makes sense. Mine were a little weird and miss shaped and I have replaced with new. I’ll check for any lateral movement.The knock pins also keep wear on the forks down. If the trans shafts shift then the forks also wear funny.
We got this done today: 1. Can’t pull dogs apart so that’s good. 2. With shift forks on flat surface they are even.Put the trans shafts back in place, then turn the shift drum into the various gear positions, then grab the gears with your fingers and try to pull the engagement dogs apart. The engagement dogs should stay in at least 50% engagement. Remove the shift forks from the drum and lay them on their sides, with the fingers facing each other, they should be the same height from the table.
stl360+450, Thank you for your input. I confirmed those 20mm washers shown on the fiche are in place on both main and counter shafts. I really can’t figure a way these “orphaned” washers would fit on the trans shafts. The ID of the washer is 16mm. I’ll keep looking!!I never laid a hand on one of these motors, but it is curious that the transmission uses 20mm washers (slightly different shape shown in the fiche).
Parts Fiche
Perhaps they are used to control endplay?
