Cataract surgery is a walk in the park. Mine were done 30 years ago, out patient stuff.Well, I’m close to getting this project finished but I may end up getting sidetracked before I can get it there . I will be going in for cataract surgery next Monday and, unfortunately, I also have a torn biceps tendon that looks like it will need surgery. That one’s gonna be a long time recovery. I will do as much as I can in the meantime but once I go in for these procedures I’ll have to stop to let things heal up.
A big time bummer for me, I had a lot I wanted to do this summer. But life can be tricky sometimes so, this is what it is.
Yeah, the timing isn't great. Someone once said "youth is wasted on the young".Yeah, I’m not really worried about it. Just a little frustrated that it’s going to put a damper on the whole summer.
Man, ain’t that the truth.Yeah, the timing isn't great. Someone once said "youth is wasted on the young".
Thanks, that makes two of usBest wishes on a successful surgery and a quick recovery. Can't wait to see this machine on the track.
The quality is obvious, but the only thing that wouldn't fit for my needs is the footpegs are rigid.Just wanted to give a shout out to Motobits. Their vintage rearsets for Honda twins are fantastic. Well designed, nicely manufactured, infinitely adjustable. If you’re looking for rearsets for your vintage Honda twin project, shop with confidence.
That’s the best position I can get due to the gap in the splines. I don’t mind not having a really strong rear brake. With all the weight on the front under hard braking it tends to lock up.Like the look of that beefy rear brake rod, if there is enough adjustment, I'd consider backing up the arm a spline on the cam to get a closer to 90 degree angle at the rod to arm. Better leverage.
I have been looking around at any and all available options. That one looks like it might solve my issue without having to cut up and re-do the cables. We shall see how it goes (eventually).That's a cool throttle
And congrats on the cataract surgery, I'm next. Hope mine goes as well as yours.On a positive note, my cataract surgery went very well and so now I can see again.
There’s really nothing to it. You’ll be surprised how well you can see after it’s done. I never realized how terrible my eyesight was until I had it fixed.The summer of surgeries I guess, glad that went well.
That's pretty strange then. The red flag for me was seeing so much cable adjuster used at the front sprocket cover and I wondered if you started there before adjusting the mechanism. I could see one cable being that way but two cables of different brands seems odd. The lower portion of many of Honda's clutch cables is similar if not the same, so you might try another model's cable (I'm using a CL175 cable on my 900)Yeah, I adjusted everything for a loose lever. Then I turned the push rod lifter screw CCW until I felt resistance abd backed off 1/4 turn, then locked it down. Then I adjusted the cable ends for the proper play at the lever.Everything per the FSM. The steel ball is in its place.
I didn’t feel any pop that I know of. I can feel the resistance of the clutch springs I tried it with a full length Motion Pro cable and got the same result.
Where should I be looking for the fix?A give away is the slot on your screw is 90 degrees off from the 2 bikes I just looked at. My screw slots run from 2 to 8 oclock , whereas yours is from about 10 to 4 oclock. The lever that the cable hooks to, should start much lower. I have less than a locknut of space on adjusters both top and bottom.
Yeah, I figured. I packed that damn thing full of grease, too.Have to remove the cover and dis-assemble. Hopefully Jim or someone else can describe it better than me. It's been awhile.
Take pictures and I'll compare against the cover I have handy.Have to remove the cover and dis-assemble. Hopefully Jim or someone else can describe it better than me. It's been awhile.
But first, just how long did it actually run? 30 seconds? 2 minutes? You didn't say, and if it was only 30 seconds or so and oil started flowing out of the left cam bearing cover, that tells me oil is up there. If you don't rev the engine a little bit it doesn't usually go flying out of an open valve cover right away, it takes a bit for that much oil to start moving around in the cam box.IDK, I opened the valve adjustment caps and they were all dry. I would think that after the engine had run there should be oil splashed around in there, no?
Also I heard very distinct ticking and saw smoke from the right side exhaust port. If it ran dry I would imagine the cam lobes and rocker pads are probably burnt. At the very least wouldn’t I need to pull the engine out and inspect this?
During assembly I noticed you lubed things up pretty good with assembly lube IIRC, so hopefully things survived. These engines have blown out clutch rod seals and left big puddles behind them and have still survived if not run too long afterward. Start with the easy stuff, wait until (IF) you see something worth gnashing teeth over. Remember, I went through this while actually riding my 450 because of the oil filter valve, and this was the worst that happened in over 60 miles of trial and error.it’s kind of a blur as to the exact amount of time that the engine ran. I was more focused on trying to get the idle to run smoothly at about 1200 rpm. I probably blipped the throttle once or twice to check that it would return to idle. All told, maybe 1-1/2 to 2 minutes.
I didn’t see the oil at first as I was on the other side of the bike. Once I heard the ticking and saw the smoke I went to hit the kill switch on the left side and then I saw the oil.
