1982 CM450 Carb Rebuild Kit
zhuffy
Burlington, VT, USA
I need to rebuild my carbs on my 1982 CM450C Custom and was wondering if anyone had some advice on kits. My bike is popping a bit on decel and I am told that rebuilding a dirty carb might clear this issue up. I know not to replace the brass but am I good replacing all the rubber gaskets and seals and such? How about the floats? Thanks in advance!
Gaskets and seals, yes. It's difficult to rebuild those VB carbs without replacing the bowl gaskets and o-rings. The floats are $$$ to get the right ones, but you only need to replace those if they've failed - most of the time they can be cleaned and reused like the jets.
I just got done with mine for the GL, essentially the same carb as yours. Use this thread for a step by step:
You're going to need:
Ultrasonic cleaner
can of carb spray - you'll use the whole thing.
assorted pokey objects like guitar wires, single or double strands from old control cables, etc.
a flat head screwdriver filed down to exactly fit the slots in the jets ( I want to say it's a 4MM wide blade with the tip filed to a 1MM thickness and squared off. LDR does a how-to on the one he made in the thread)
Patience
Camera phone. Take a lot of pictures of the linkage before hand.
Air-cutoff valve daiphragm set, (Honda) #16048-429-771
superseded to: #16048-443-901
or K&L Supply #18-2795 ?
or K&S Tech. #1003-0299 or 1003-2028
accelerator pump kit, Honda #16021-438-671
= K&L Supply 18-2808
= K&S Tech 1003-1926
Air-fuel mix pilot screw set :
K&S 56-2000
Keyster (SiriusConInc) rebuild kit : KH-1172NF
K&L float valve : 18-8955
K&L float bowl O-ring (4x) : 1003-0497
Also, what kinds of carbs do I have if you're able to tell by the year and bike? (as in VB22, 21, or 24): It is a 1982 CM450C Custom. Do you need a pic?
The information is on the left side of the body above the float bowl mating line. Should be VB22?
Aftermarket air cut valves are fine to use. There's tip on that in the Rebuild sticky posted earlier
LDR, you seem to be the jet/needle guru. I know you have discussed this in previous discussions. I really need a source for the suggested replacement parts.
She, Mabel, is 1982 CM450E. I have rebuild the carbs using randacks $20 special rebuild kit. I know, scold me later. All brass replacement, which I now know is frowned upon. Prior to the build, it was painful to ride, spluttering shaking, barely pulled above 60 kph, backfired, front fired, (burped and farted fire as we used say with the cars) blew smoke, left side ran way hotter way quicker, was a general misery to ride. A cheap rebuild fixed 93.5% of that, leaving now just the mid range quiver. The kit I bought had different air cut off valves, so they were not changed. I cleaned the existing ones and replaced them. I get almost no backfire on downshift deceleration. The stem shafts were a mm thicker and rounded as opposed to the squared ones in the carbs.
I am dealing with, after a rebuild, bog out, gasping and shudder at mid range rpm. eg; in 5th, trying to cruise between 80 kph and 90 kph, I have to be really gentle on the throttle otherwise she will protest, after 90 though, she'll open up and keep pulling very well. It does happen periodically in 2nd, 3rd and 4th, but it is less noticeable, as most of the time i really pushing to catch up my brother's 650 before i get left behind to cruising speed at about 80 to 90.
Where can I get the ridabiltiy performance upgraded jets #61C? And to verify, that is a good step in the right direction?
I know there is a vibration from the engine at certain rpms, forcing some an early shift, which I have noted, but the quiver I refer to is fuel related as there is a stumble in the motivation. I also get a vibration from the front wheel, as it turns out is oblong not round. It's heavily weighted to counter the shake. I am looking for a wheel, which brings up another question? Is there an article, paper, video, anything related to replacing drums with disc on the front end of a CM? I figured now would be the time. After 5 day trip, loaded with camping equipment, the braking is a bit squishy.
I have many questions and will start separate threads for each.
Cheers
Well I'm hoping that you saved the original jets. Looking at Randakk's page I see this kit https://www.randakks.com/carburetor-kit-cb450-1983-1986-premium.html but nothing for the CM versions.
Your original jetting was a 72/115 combination, I'll recommend a 75/118 combo. Jet-R-Us sells original Keihin jets plus no name versions. Only use the Keihin jets https://www.jetsrus.com/a_jet_kit_street/honda_400_CM400_1980.html Yeah it says 400 but the jets are all the same.
I'll suggest going thru the carbs again using this thread https://vintagehondatwins.com/forums/threads/how-to-rebuild-the-vb-carburetors.24/
Float level is of concern because the only known correct float valve needles are from Honda, aftermarket ones are too long or short.
Hey LDR, I am revisiting old threats for clarity. When you recommend 75/118, is that primary/secondary respectively?
I have been confused with the naming of the jets and it needles, pins etc
.I have the 61c needles, and replaced the primary and secondary (as far as I see with 74/118. I have no power passed 2500 rpms now....
Yes. 75 primary and 118 secondary.
"have no power passed 2500 rpms now...." Make sure you didn't switch positions of the jets, Smaller one screws directly into the body and is closest to the mixture screw.
Is this with the airbox connected? air filter in place with lid screwed down?
I am going to double check all that.
I was planning on removing the air box and replacing it with individual air filters (cones) how will that affect the jets/needles etc?
Some older Hondas are less bothered by it, but your bike is one of the most sensitive to complete airbox removal for pod filters and it will not run well without a LOT of jetting experimentation.
So she will be temperamental, like her rider...lol
Should I start with big jets or little jets?
I've seen a few cafe builds with this bike and not much detail in the carbs. I was also wondering if down the road a set of mikunis would be beneficial.
Mikunis might make it easier only because they're not CV carbs, but then you have more of the trial and error seat of the pants tuning to get them jetted right.
Here are a couple of threads to look at.
A long time ago I found a place that would jet the mikunis according any mods in the I take/exhaust. Unfortunately I cannot, for the life of me, find that again. Still lookin though.
In the meantime I am going to remove the carbs ... again... this weekend and rejet with different sizes. It will be a loooong weekend.
Any other suggestions, clues, tips would be vastly appreciated. I have decided to go with the pods, I'm this deep already....may as well go all the way, in for a penny, in for a pound, eh?!?
IIRC the best jetting has been 90/125 with pods. You will need to make a ram pipe, similar to a velocity stack, that's the length of the airbox to carb boot. Entire length no just what you see.
These carbs really don't like pod filters and using them will mean some compromising in riding style and throttle use.
The company you're thinking of is Sudco which is out of business.
90 is big. I'd have to find some.
What would one make the ram shaft out of? Is there such thing as an aftermarket piece? Ultimately best not to fiddle with it.
I have decided to just put it back together as she came. I will fully reassemble the air box and take it for another ride, see if the 75/118 jets are working. I will figure out another solution for cleaning up the electrical nest.
Thanks for all the help fellers, I will be back and forth whilst I figure out the netting points
I think this is a wise decision. The headaches resulting from making the bike cosmetically pleasing aren't worth it IMO. But then again I like bikes that start and run reliably every time.
You are wise. I too think it the wise choice. Something about just getting on for a ride is a very pleasing idea. She has been so good to me so far, I should not mess with her. Thanks!
So, I got some OEM float needles and changed those. Yup, they were about 1 mm shorter than aftermarket. I double checked the primary and secondary, and if I am right, I am very, very confused.
I got the 'delux kit' kit from 4into1. It has what I am hoping some superfluous bits in it.
Nothing made sense. So I did what was logical. Each kit had 6 jets in the kit. (Again, here I may be misnaming the bits.) 4 little screw types with labels, 72, 75, 108 & 118.
Two of the longer shaft type jets(are they jets) labelled 38 and 42.
These two fit only in the slow jet, I erred on the side if caution and out in the 38 under the rubber cap.
In what I think is the primary, I put in the 118 small jet. And in the secondary, I replaced what I thought (think) is a one piece jet, shaft type but larger than the slow jet. I will post a couple pics after this...
What I am realising now ... After the second strip down and reassemble, is that the secondary is two parts, yes? And the 118 should be there and the 75 should be in the primary.
As the bike is stumbling and jerky at slow speed and idling, can I safely say that that the slow jet should be 42?
The first pic is the kit, minus the two jets that are in the carbs.
The second pic is all jets, yes? If I am terminologically challenged, please help me understand the correct terms.
The third pic is just the assembled bowl. For confirmation, from the foreground to the back ground, there is an mix screw, the primary jet, the slow speed and then the secondary. (The plug was installed prior to bowl attachement.)
