It will depend on the amount of material removed, do you know a measurement of what has been or will be removed?Hello been a bit, started cleaning gaskets on head and piston side can actually feel a low spot,(also put a piece of flat stock and can see thru it and head in that area) I believe someone may have been here before, I know cars and heavy equipment head had to be perfect to hold compression also could only remove so much material to make flat.
Gasket area is supposed to be raised.
One area it was not. Showed it to a machine shop and he said complete raised area will be gone.
Has any had head work done and will she run or will pistons hit valves.
At work no pictures
Was this an automotive machinist? They like to sell a 'deck' job, but I think it is usually not needed or even a good idea. I prefer to deal with a powersports machinist, who is very familiar with small displacement motor like motorcycles. If they don't have a boring bar small enough for to do 49mm bores then stop with them right there. Others will hopefully chime in here, but warpage on a small twin head is not very common.Hello been a bit, started cleaning gaskets on head and piston side can actually feel a low spot,(also put a piece of flat stock and can see thru it and head in that area) I believe someone may have been here before, I know cars and heavy equipment head had to be perfect to hold compression also could only remove so much material to make flat.
At work no pictures
Our highly experienced veteran members are always right and I'm really just a novice rebuilder so weigh carefully all advice. I do remove the valves for deeper cleaning and to inspect the springs. A good opportunity to get some good close pics of the seats and valve faces.Thank you for explanation, I did get fsm from forum. I don't plan on doing mine as they are sealing. I did soak them and clean carbon off them, and I do not have a money tree so yes anything reusable is reused.
What are the 3 part numbers? For anything else in the engine world the last 3 digits would be the size (000,010,020) Over bore.So brought cylinder and pistons to a vintage motorcycle machine shop, he measured up pistons and cylinders. Said pistons can be used, but since apart if available replace. He also says walls in great shape i can get away with standard pistons and rings.
I see 2 different #s in fsm for pistons. Just last 3 #s.
Whats the difference? What I believe it goes by engine serial # mine starts with 501 so guessing need the 13101-206-010
Any help with this would be greatly appreciated
13101-206-010 is second #So I have a 1965 benly ca95 150
Looking for standard pistons, in factory service manual they list 2 part #s for standard. Is there a difference between them.
13101-206-000 and 13101-206-010
Cool. I've found more info at Tytronics ebay store before, coil requirements, etc. I'm not currently looking, but good to know.
Use gasolene to check leaks in possible cracks or head valve seat sealing. It's thinner and will penetrate better.Well cleaned up crack/molding mark put some oil on it walked away came back still there, next have cylinder off so put bright light shining into block in darkness and could not see any light coming thru. Next tried borescope did not fit great around metal sheild but could not see anything or enough.
Going to change seals and start putting back together.
I believe it to be just molding marks.
