I started my '71 CB350K today for the first time this season. At first, it idled high (around 4K rpms). So, thinking something was wrong, I shut it off, checked a few things and started it again. This time, it ran much better, but it blew a lot of white smoke from the right exhaust. After a minute or two, the smoke got lighter but never quite went away. After 10 minutes of idling, the smoke would occasionally stop, but would then return (light smoke).
I had done some maintenance since the last time I started it, so I'm wondering if it could have been caused by something I did, specifically the float adjustment that I did on the carbs. Last season, the left carb was overflowing. So I replaced the float and needle valve, and adjusted the float to 23mm. For consistency, I did the same to the right carb even though it hadn't been overflowing. Now, neither are overflowing. But is it possible for the right carb to be delivering too much fuel to the cylinder if the float isn't adjusted quite right?
Other things I did since the last time the bike ran: new ignition coils, new condenser, cleaned and adjusted the points, adjusted the cam chain tensioner.
EDIT: The more I think about it, it seems more likely that I wasn't precise enough with my points adjustment and that it's firing late. I'll check that soon. But I'm still curious about the carb float height and if that, by itself, could cause a rich mixture
