Don't overlook our Welcome Package, it contains many links to important and helpful information about functions at VHT like posting pictures and sending PMs (private messages), as well as finding the parts you need.
I had been thinking for the last couple of years, that I had a broken wire, since my right side turn signal didn't work half of the time, I could always fix it by jerking the wire, so I pushed fixing it for longer then I should have.
low and behold the wire was fine when I dissasembled the handlebar controls.
since the 3 wires mesured good, even when I twisted and turned them, I started to clean the contacts.
It is a simple contact breaker. the 2 outer pins are left and right, and all 3 middle pins are ground.
My outer pins are looking really bad so a good clean with a brass brush and its good again.
so I put the breaker on the pins to test out the connections from the connecter side, and still nothing.
I try mesuring everything alone again and it's all good.
All gound pins mesure to gound as well, but then I mesure the gound pins again after moving the board, and this time theres no connection, so I suspect it is the connection from the pin to the wire. I desolder and remove the old solder, as I reflow it oxidation emerges from inside.
Honda used solder to brigde the 3 pins, this is bad practice and will break from vibrations, like it did here, symptoms resembled a broken wire.
This might only be a problem on mine since it could be that the gound wire was supposed to span all 3 pins when soldered.
I stripped a single core wire to bend around the 3 pins and make a solid connection then resolder it.
polished the contact pins to 4000 grid and lubricated it with some dielectric grease and called it a day.
