Xylocopa
Hi everyone,
This ones been tricky for me. I'll put the issue up front and the long story below, for those interested.
Short story:
I'm having a lot of trouble setting the ignition timing after replacing both coils, the condenser, both points, and the points mounting plate. No matter what guide I follow, be it the clymer manual or the those guys in Houston youtube video (or any of the various videos on setting points) I cant seem to reliably set them in a way that causes the test light to flick on and off when it should when I rotate past the F and LF marks.
Long story:
(this is my first real post so please bear with me, if I'm messing up with formatting or this is in the wrong topic area let me know and I will edit and revise as soon as I can)
this is my first motorcycle. I bought this bike off a buddy whod had it taking up space for a year. After replacing the battery, the bike ran mostly ok, I had to figure out the hard way how to use a pidcock valve, and there was some funkiness with backfiring and weird power issues. In hindsight, this bike was probably running mostly on one cylinder, as I realized by being zapped in the legs a few times that the lead from the left coil was cracked and arcing out. I went probably way too overboard and replaced the condenser, both coils, new spark plugs, rebuilt both carbs (thought it was the float bulbs, realized I didnt know how a pidcock worked) , adjusted the cam chain tension, valve spacing, cleaned/sanded off old gaskets and replaced them, and finally threw new points on. after doing all this, ladies and gentlemen the motorcycle no longer starts. I've been tearing my hair out trying to figure out why I cant seem to get the ignition timing correct, there is definitely voltage in the system, the points are getting power, but the plugs are NOT firing. happy to take a video of the situation but I thought I'd start with an explanation. Thanks in advance.
Short story:
Long story:
