Stator Harness Grommets
fxray
Central Illinois
I'm working on an SL350 K0 stator harness, but I think they are the same for most all of the 350s. Does anyone have a source for the rubber grommets? They were originally sold as part of the stator assembly, so not available as a separate part number from Honda. Maybe there is a reproduction available?
Rubber suppliers have them, or base material to work with, I'm getting my stuff in a shops like this: https://www.technirub.nl/webshop, or equivalent (for example :https://www.technirub.nl/doorvoertules-en-kabelbeschermingstules.html). I use the square type and cut it in the shape I need. If not possible I have rubber base material and cut the grommets myself. I also buy (almost) all my (Viton) O-rings and oil seals in shops like these.
Unfortunately the website is in Dutch / German, like most specialist technical webshops.
Thanks, jensen. I'm able to read that Dutch / German website quite readily. Well, alright . . . I can read it after I click the button that makes it display in English. Anyway, I get your point. I will do some checking for some grooved, square-section rubber blocks and modify to fit. McMaster-Carr should have something. Thanks.
Ray
After a lot of searching for the grommet for my SL350 K0 stator harness, I couldn't find one similar to the OEM tombstone-shaped grommet, and nobody on here from the USA chimed in with a source (thanks, jensen for chiming in from the Netherlands). Even McMaster-Carr had nothing like it. Here is a picture of my old one, which looked like new from one side, but looked perished from the other. In any case, it is as hard as a piece of petrified wood:
There was one website that showed the correct shape but did not show anything close to the size I wanted. Their site said to inquire if a different size was needed, because they had over 18,000 different grommets in stock. I did a screen grab of their generic diagram, edited it to show the dimensions that would fit, and posted my inquiry.
They responded to say they had nothing, but could tool up to mold it if I told them how many I needed. I told them that I only wanted a few and it was not worth their time.
So, for what it's worth, I went with a package of these closed-center grommets from AutoZone:
The idea is that you can punch the proper sized hole in the middle yourself:
I unpinned the female connectors from the round plastic plug on my stator harness and cut off the old, hard-as-glass vinyl sheathing. I replaced that with some 8mm ID sheathing that I had from http://www.britishwiring.com/category-s/278.htm, made a new neutral switch wire to replace the one that was nearly broken in two, punched the grommet center hole to about 8mm, and put it all back together.
By comparison, the new grommet is round and a bit larger O.D. than the old one:
By the time it is squeezed to fit the slot on the engine case, it will assume a shape pretty close to the original. The vinyl sleeve flattens out to keep the hole in the grommet fully sealed.
From there, I had to put the connectors back into the proper holes in the round plastic connector, and it should be ready for another 53 years.
Purists will note that my green/red-striped wire is a bit darker than the original Honda coloring, but that is because it came from British Wiring as well. The male bullet and the female pin connector crimped onto the ends of the neutral wire came from
http://www.vintageconnections.com/Products/Connectors
If my neutral wire color is a bit "off", the stator wires are pretty well "off" as well. The Pink, Yellow, and White have turned into Faded Motley Red, Amber Peach, and Dirty Clay. But, before I unpinned them from the round connector, I made note of the numbers molded into the backside of the connector itself. The rib on the outside of the connector keeps it aligned to the correct pin position as it is plugged in to the mating connector of the main harness.
On my 1970 SL350 K0 harness, pin #1 is open, pin #2 is Pink, pin #3 is for the green/red neutral wire, pin #4 is open, pin #5 is Yellow, and pin #6 is White.
None of the pins have continuity to the stator frame, which is good!
Pin#6 (White) to Pin#2 (Pink) has .5 ohms resistance.
Pin#5 (Yellow) to Pin#2 (Pink) has 1.0 ohms resistance.
Pin#6 (White) to Pin#5 (Yellow) has 1.5 ohms resistance.
I figure that each coil winding has a resistance of 2.0 ohms.
Pink is the common wire lead. It connects to one end of the four coils on the White wire. These four coils, wound in parallel, give the total of .5 ohms (calculated by adding the reciprocals of the four individual coils at 2 ohms each).
Pink also connects to one end of the two coils on the Yellow wire. These two coils, wound in parallel, give the total of 1.0 ohms (again, calculated by adding the reciprocals of the two individual coils at 2 ohms each).
The White leg is in series with the Yellow leg, so their total resistance is added directly
1.0 ohms + .5 ohms = 1.5 ohms
At least, that is how I suss it out.
Ray
Nice job as usual Ray, this is certainly an issue for some of us. I've been fortunate to get away with using some sealer around the alternator grommets I've encountered as they've only been on the hardened side of deterioration, yours looked as rough as any I've seen. I'm not surprised you couldn't find any among all the grommet suppliers out there, it's not a typical shape.
Well, 15 months further along, this alternator that I posted about here is not charging. I have been trying to think of a reason why the stator leads could check out fine for the normal resistance, not be shorted to ground, and still not produce power. My rotor magnets may be weak. I guess I need to pull off the stator cover and see if the rotor will hold a wrench or something.
A couple of factors may be involved with my SL350 K0 lack of output from the alternator. I have always heard that a permanent magnet rotor that is not in use should be stored inside the mating stator. The stator acts as a "keeper shoe" for the magnetic properties of the rotor. If the rotor has been stored open for a long time, it may have lost a lot of its magnetism.
I couldn't remember for sure how the rotor on this bike was stored before I got it, so I went back and looked at some old pictures I had. Bingo! There it was:
The stator was inside a plastic tub, still bolted into the side cover. I would guess they were stored separately for at least five years. I can't remember for sure if I checked the strength of the rotor magnets, but I definitely should have.
The other thing I have read is that a stator can check out OK for coil resistance, and show no continuity to ground, yet still fail to produce power when put into operation. The reason for this is that the coil wire can be shorted inside the windings (loop to loop) yet not to the frame of the stator. This theoretically would not make a significant change in the small resistance reading on the ohmmeter but could effectively reduce the number of windings cut by the magnetic field when the engine is running.
This morning, I found a very reasonable deal on eBay. A seller was offering a 1970 SL350 K0 stator and rotor together, along with the side case that holds the stator, and the round alternator cover. The harness looks pretty good for being 54 years old, and both the rubber grommets look to be intact, along with the round, plastic plug at the end of the harness. It even includes the neutral switch still plugged onto the harness wire. All of this for US $19.95, and a 25% discount if I used the seller code he offered. By the time I pay shipping and a royalty to our governor's back pocket, it all comes out to $32.66 delivered price. I went for it.
Even if I find that the stator has a dead short, the rest of the parts are worth more than that. If nothing else, I can make an oil shield by cutting a hole in the round alternator cover for use in dynamic timing. I have always wanted one of those. Now I just have to wait for the parts to show up.
It's probably bad form for me to quote myself, but I did it here for continuity. Here's some follow-up to the last time, when I had popped for an eBay charging system. The parts showed up in good order. For $33.16, including tax and shipping, I got:
A nice LH crankcase cover and the round alternator cover, with the bolts. It could use polish or paint, but there are no cracks, gouges, or even scratches:
The neutral switch was there too, but it will need a drop of solder on the contact point:
Also, the rotor and the stator. The two rubber grommets were in nice shape. This was the original reason I started this thread -- I was searching for the grommets:
The only thing I decided to work on was to replace the brittle and cracked harness sheath, which is normal for a 54-year-old Honda:
With the harness sheath opened up, the wires still even had their white, pink, and yellow colors. The green with red stripe is, of course, the neutral switch wire:
These pictures were after I did some cleaning, but the parts are all very nice. I checked the resistance values on the stator windings, and they checked very similarly to the existing stator already in the bike, from which I was getting zero charge. Here's what I found:
  • white to pink = .6 ohms
  • yellow to pink = 1.2 ohms
  • white to yellow = 1.6 ohms
The proper size of vinyl sheathing for this harness is 10 mm inside diameter. I had some 8 mm (too small to accommodate the four wires) and some 12 mm (too big for the hole in the grommet), so I ordered some 10 mm vinyl from British Wiring at $1.50 per meter. I got 10 meters at that price, just to feel better about the $10.50 shipping cost.
So, with this stuff on hand, I decided that I wanted to only change one thing at a time to try to figure out why I was not getting charge from my SL350 K0 system. I think it would be fine just to remove the round alternator cover and extract the rotor without disturbing anything else, but I got to worrying about maybe losing the woodruff key or a piece of the sprag clutch in the process. With my luck, it would fall down into the oil drain-back hole and wind up in the lower case half. So -- I removed the alternator cover, the LH crankcase cover, the stator, as a single unit, and then removed the rotor.
With the rotor out of the engine, I did my scientific magnet test on all six of the embedded magnets. This is where I suspend the rotor, one magnet at a time, from a steel hammer, like this:
If the magnet is strong enough to support the weight of the rotor, it is probably strong enough to do its job creating alternating current (at least in my mind).
I was pretty bummed out to find that my existing rotor seemed to have the same strength as the magnets on the rotor I had just bought from eBay. I was at a loss as to why I was not getting any charging. I had hoped to find that my existing rotor had weak magnets. Oh well, I went ahead and put it all back together, with the only new content being the eBay rotor. I reinstalled my original stator.
Now for the part I cannot explain -- I first tested my battery, with the ignition off. It was showing12.3 volts, which is understandable since the bike had run a few miles on total loss (no charge coming from the alternator). Also, the bike has been sitting for a couple weeks with no tender hooked up, and I have started the engine several times just to show some friends that the bike would start and run.
Next, I fired the bike up and connected the same VOM that I had used previously. Before, I could not get anything but a 0 Volts AC reading from the alternator leads, and the DC Volt reading across the battery posts was showing 12.8 volts with the engine running. This value did not change, regardless of engine rpm.
Today was a different story. With the eBay rotor installed, I was getting 18.5 volts AC from pink to either white or yellow (I didn't distinguish which was white or yellow), and 15.8 volts AC from the pink to the remaining wire (which was either white or yellow). This was at idle speed of 1200 rpm. Revving the engine, the reading was going up into the high 50 volts AC range on the meter. When I gave it a handful of throttle, the meter showed 75 volts AC!
At that point, I plugged the alternator white plug back into the harness and buttoned things up. With the meter set to DC Voltage, I was seeing 12.5 volts across the battery posts at idle speed, but now it would go up to 14.2 - 14.5 volts as I revved the engine. This told me that the alternator was working, as was the Sparck Moto Rectifier/Regulator. Again, all I had done was change out the permanent magnet rotor!
I took it out for a 9-mile ride, with the headlight on of course. When I got home, the battery was showing 12.5 volts with the engine shut off. Remember it was at 12.3 volts before the ride. So -- the charging system was running the engine and the head and tail lights, and still putting a little back into the battery. I was not making any special effort to keep the rpm higher than normal during the ride. I had also stopped and restarted the engine twice while I was out.
It's ALIVE. Here are some pictures taken when I was well beyond walking/pushing distance from home:
That was a great score on eBay. It seems to me that the alternator covers are hard enough to find, let alone in nice condition with the rest of the related parts for a reasonable price. Thanks for including the link to British wire.
I can't get over how satisfying the candy paints are to see in different lighting conditions. The candy gold can appear almost orange at times and all the color variations are nice.
It's hard to figure how a rotor change gets the bike from no output to good output. Makes me wonder if something changed with the stator wiring in the process of removing the crankcase cover and reinstalling it. Hopefully it's not a transient condition.
That was my thought as well and wondered if there was a bad connection or ground that got "fixed" in the cover replacement. Keep an eye on the lights for awhile when riding to make sure they brighten when you run the engine up a bit in case it was only a temporary fix.
I find this as perplexing as you do, but there really are no places for a "bad connection" to accidentally get fixed in the process of removing /replacing the stator. There are no ground connections involved whatsoever. In fact, if any of the wires on the stator had ground continuity, the system would be junk. The round plug on the end of the stator harness was unplugged when I was testing output from the stator on the bike. I was holding my VOM leads to the female pins in the plug itself. There was no other harness involved in my testing. This was the case when I could get nothing but 0 Volts AC before the rotor change, and also the case when I was getting up to 75 Volts AC after the rotor change. The testing was done right at the white plug.
I suppose the possibility exists that the pink, white, or yellow wire could be broken inside its insulation, where the broken copper would be invisible. However, I stripped the old, brittle harness sheathing off this harness back when I was first putting the bike together. I inspected the wires for bad spots. I also did the resistance checks on the stator windings by testing at the white plug end of these wires. I replaced the harness sheathing back then with the last of my 10mm inside diameter sheathing. I have checked the resistance again several times after the stator was in the bike. Any broken copper would preclude that test from checking properly. I am convinced there can be no broken copper. Here is the stator and its harness. This is the original one from the bike and the one that I am still using today:
When the permanent magnet spins inside this stator frame, and the lines of magnetic flux that surround the rotor are swept through the copper windings in the coils of the stator, voltage is induced. Essentially, what is shown in the picture is the entire, closed system, except for the rotor. There are no other parts or connections involved.
So, for whatever reason, the bike is working great in all respects. I had it out for another blast around town after supper. And blast is what it was. The exhaust note sounds great, and the bike handles quite well. About all I have to do is brush my thumb across the starter button and the engine is purring. It's been a long time coming!
What is that hex-shaped multi-tool in a couple of the recent photos? Looks like something from NASA, but I assume it's useful for removing wire ends from the plastic connectors? 1 of 1?
You are correct -- that is its purpose. Here is a picture with the card it was on when I got it:
It is sort of a universal tool, intended for a variety of connectors. In the case of these stator connectors, or the round connector for the ignition switch, you select the hollow prong that will slide over the female pin inside the plastic body. There is a tab on the outside of the pin that that catches on a "shelf" inside the connector body. It must be bent in against the body of the pin to let it release from the plastic connector.
With that little tab bent in against the body of the pin, the pin will come out the back of the plastic body. The tab can be bent back to its original shape when the pin needs to be reinserted into the plastic body. Do this too many times, and you must crimp on a new pin.
Thanks for explaining and sharing the picture with the original card. That looks like a great tool and quite a step up from a small, flat-blade screwdriver. I found one for about $13 on eBay using the model number shown.
My favorite threads/posts are those that allow me to learn.
I just found it on Amazon for $12.71 and going to order. I had been using mechanics wire to push the tab down which works but not well. There are a bunch of terminal tool kits on Amazon but I like the simplicity of this one.
I found that using Hondabond or Yamabond around one of those shrunk rubber grommets works very well to seal it;I let it cure with a piece of tape over the flat side of the cover while off the engine and it has never leaked after I let it cure-up for a few days.
That's a good idea to do that. However, I didn't do it this time, because I was trying one thing at a time. I wanted to know where the fault was. I was almost certain I would be going back in there to change out the stator. I was amazed when the system started working with only the rotor change. I even reused the gasket for the LH crankcase cover, thinking I would put in a new gasket and seal the grommet with Yamabond when I changed the stator. Amazingly, there are no leaks (so far). The gasket was almost brand new in this case, but still . . .
I had the the thought that that grommet is something that Clauss Studios should offer.
They specialize in reproductions of rare rubber and plastic bits.
I see that Clauss has a lot more parts available than the last time I looked, but it also seems he's gotten a bit greedy on some of the prices. $79 for the rubber ring around the CB77 speedo?? And there are a few other bits there that seem overly pricey too. I believe this is the same guy who, during an inquiry about it, asked Chris (12ozPBR) for a sample of a CB450K0 air filter connector rubber and never sent his usable sample back to him.
I don't know what process they use to mold their parts but I imagine there's some tooling cost they want to recoup before the price comes down.
But I agree, $79 does seem a bit much, perhaps they don't sell many of them.
I used the rear fender rubber piece they offer for the CB/CL350 ($18+ shipping) and was happy with it.
The rear fender rubber piece,is that the factory rubber 'splash guard' type part that keeps water spray off of your taillight ?
No, the piece that goes at the front of the rear fender. It fits between the tool box and the fender.
The one on my bike was broken and rock hard.
