fxray
A guy I know is working on an SL350 K2 for a friend of his. The fuel tank was in pristine condition as far as the paint goes. He had some rust inside and tried to clean it out and use POR-15 liner. It sounds like he did not get the coating mixed properly and the liner failed when he put fuel in the tank (after letting the liner set up for a couple of weeks). So . . . he tried vinegar to remove the failed liner and got most of it out. Problem now is that the vinegar destroyed the petcock bung. It literally ate half of it away. I have been trying to find a replacement bung on-line but am having no luck. I am surprised to find than most weld bungs are made only with internal threads. There are a number of places that sell 22mm externally threaded weld bungs for Harleys, but he needs an M14x1.5 externally threaded weld bung. When I searched on here, the only person who mentioned a petcock bung was RockReef, and he hasn't been seen since June. Anybody else done this before?
