Wacky
As stated in my introduction as well I've just aquired a 1982 CM250C, single carb version.
It's been someone elses project, the usual. Started the build sometime may last year.
Basically took everything apart, not really organized but also not a mess. (although everything is still dirty and greasy.. grr)
After getting it home in my girlfriends car,I started by taking it all out of the boxes and assorted containers.
Right now I quickly put the forks, swingarm and tires back on the frame, to get a sense of dimensions and current state.
As you can see there's already been a frame loop welded in, a different rear fender attached and some supports build in for a battery tray.
I am considering cutting out those supports to be able to fit the airbox, but unfortunalte the battery tray has already been cut up.
The carb has got a pod filter on it now but probably not rejetted for it.
Current plan is to first clean all the parts, see what I want to use or not and then go from there.
Then cleaning up the frame for paint, prefer to get everything nice and clean before putting the engine back in the frame.
