Cycleranger
Or I might find one when I'm trying to install the cam..They likely got jostled out of place during assembly. You will probably find them stuck in the goo under the windage tray after you split the cases.
So Yesterday I'm trying to install the cam and it's not fitting through the sprocket. It's like I can't get enough slack or the chain is one link short.
So I'm scratching my head and decide to rotate the engine around one time to see if the chain is kinked or binding or something. I feel some resistance at one point and I'm like wtf?
So this morning I got my crappy USB snake-camera thingy (it's not a bore scope) and stuck it down the cam tunnel.
After much fiddling I get it to focus on this little piece of...something.. next to the crank sprocket. At first it looked like blue RTV but that was just the lighting.
So I poked a piece hanger wire down there and got it loose and rotated the engine over on the stand and jiggled it until it fell out.
Somehow one of those lost roller pin rubbers got onto the crank sprocket and was interfering with the cam chain.
It probably dropped on there and stuck when I had the engine upside down while I was cleaning it. I flushed the case after I pulled the head and looked down there before I replaced the cam chain and put the cylinders back on but I missed that.
(It's NOT one of the new ones I installed, I made very very sure they were in place when put the jugs back on.)
Anyway, after that was taken care of I didn't have any trouble getting the cam installed at all and everything rotates just fine.
And I guess maybe the other missing roller pin rubber might be still in there too. I may never know. Or I might someday.
I still need to check end play. The replacement cam came with a .10 spacer so I assume I'll need at least that.
(The old cam had .40 worth of spacers on it. Two .10's and a .20!)
