Cycleranger
Day one. So I bought this bike in 2016 and for various reasons it was only today that it finally hit the lift.
Here's what I'm starting with. The PO had it running but just barely, he did the bare minimum to get it there.
It was missing the air boxes and the side covers. I've gotten replacements in that time. I also got the front muffler guard.
It sounded ok, no excessive top end noise or smoke. Went through the gears ok. but we'll see. The speedo shows ~14K miles which I believe is real. It's surprisingly rust free, even the tool box!
The tank looks pretty good inside but has that dent. I have another '71 tank with really nice paint but it has a similar, smaller dent in the other side. I might see if I can pop out the dent. Not really concerned about it, the bike needs repainted either way.
The mufflers look really good, amazingly good in fact, all things considered, although I noticed one of the brackets was broken. The break looks fresh so I guess the PO did that. Might be a hassle to repair without damaging the chrome.
Today I got a closer look at the engine and I suspect it's had the top end off. It's leaking a bit and I can see some RTV around the gaskets. I don't believe the PO did that, he never had the engine out of the frame. So I might just pull the top off and refresh the gaskets at least and discover what other potential horrors might be there...
Started tearing it down and discovered some silly things that Honda did. Like I have to pull the swing arm bolt to remove the passenger foot peg mount and take off the fork caps to remove the gauges. What the hell Honda..
Anyway, this should be both educational and expensive for me.
