SomersetChris
I've just spent a couple of hours trying to strip the front brake master cylinder - who designed that?
Of course the piston was seized in there, but the clip holding the remains of the rubber boot & retaining circlip were the biggest problems - only access via the hole where the lever pushes the piston.
Circlip pliers either to big for the hole or too short to reach, so a long time cursing with long thin screwdrivers until the circlip gave up.
Inside the reservoir there's "10" stamped but the piston (& bore) are 14mm - any ideas if the 10 is significant?
Then I had to beat the piston out, using a long thin punch from the hose connection end. May try a reamer (silicon carbide brush) fitted to my drill to clean the bore.
I've done that before with a BMW cylinder - but that was cast iron.Next on the list is the caliper - seized of course.
I think I prefer the drum brakes on my K1!
