misskatlizzy
Hi all,
This is my first question post. Thank you in advance for your advice.
My '80 CM200T was a barn find. She sat for 13 years before I got her. After putting 3000 miles on the bike, the inevitable happened. All the gunk let loose and every gasket and seal started leaking. Instead of nickel and diming the repairs, I decided to dive right in and do a full engine teardown. This was aided by a troubling noise coming from the transmission. I suspect the bearing on the countershaft has given up the goat, but I won't know for certain until I'm in there.
I'm writing this post to mainly ask for any tips or tricks from folks who have gotten this deep into a Twinstar motor. Is there anything to look for while I'm in there? Any perils to avoid? Also, how do I go about compressing the piston rings to get them back into the cylinder? Is there a trick for that?
Also, I'm learning to hate JIS screws. Has anyone had any luck with replacing them with hex heads, or should I suck it up and deal with them?
Pictures attached for reference.
Thanks again,
Kat
Thanks again,
Kat
