I'm rebuilding a pair of CB360 carbs, one of which has a mangled choke flap spring. The spring must have broke at some point and someone unwrapped two coils pretty sloppily to act on the flap. I was concerned the sharp 90* angle off the wrap of the torsion spring would be a weak point to break in the future. The factory spring measures about .013" and has 10 wraps. I ordered some .015" "music wire" the measures .014" and made a new spring with 10 wraps and a little preload.
To install I drilled the pot metal out of the end of the choke flap using a 5/64" drill bit, and disassembled the choke flap. Reinstalled with the new spring and capped the end by filling the hole with JB Weld. I considered peening or crimping the boss that the pin goes through, but given how small and fragile it is a figured an epoxy cap might be better. The next guy might need to replace this spring in another 47 years, so this will give him more to work with. Always think of the next guy... Anyway, my eyes aren't what they used to be for this small stuff, so I hope it came out better than it was.
