CDI compatability
To be clear all of the CB/CM 400/450 manual trans CDI's are the same from 1979 thru 1986, 1978 CDI's used bullet connectors on the Blue/White connection instead of the plug found on later models. Changing connectors is all that required to make them work.
Yes, and I make adapters for that as well if you need one for the 78 connectors so you don't have to hack up the harnesses.
