But when you consider that the factory-intended clearance is .0012", it would be hard to get them too tight without having damn near zero clearance.but I find the 450 tricky to adjust and I worry about being too tight.
Thanks. That’s good to know. Truly.But when you consider that the factory-intended clearance is .0012", it would be hard to get them too tight without having damn near zero clearance.
Yeah, that was my thought and I mentioned it earlier in the thread.The really high compression number is most likely due to too much oil added. The TDC combustion chamber is only @25cc's so adding more than 1-2 cc's of oil is going to make a big jump.
It always warms my heart seeing another Bomber out there! Congrats!It ain't hoarding if your stuff is cool!!!
Yesterday I was sitting at the kitchen table of a family member with a long history of antiques and buying and selling treasures that he finds in his travels. I casually mentioned that if he ever comes across any cool old bikes to let me know. "As a matter of fact" he says "I found something the other day. An old Honda Black 'something or other.' It's sitting in the garage if you want to have a look."
30 minutes / $200 (Canadian dollars, so practically free) later and it's in the back of my truck ready for the drive from BC back to Alberta. Never leave home without a set of tie-down straps! Trouble is that I have 3 partially finished project bikes sitting in the garage already. My partner has been largely supportive thus far but on the phone I could detect that I may have discovered where the line was and I was dangerously close to crossing it.
This is certainly a serious project but it seems achievable.
-Motor has been pulled and is free (so I was told and I have no reason not to believe) When I laid the motor on it's side for a few second oil appeared on the ground so it's not dry.
-Haven't had a look at the serial number plate yet so not sure of the year. Will investigate when I'm home.
-No seat or side covers, haven't noticed anything else missing yet.
-Tank and fenders in rough shape.
-Brakes seized.
-Exhaust has been destroyed but I have a set of old Triumph mufflers if anybody needs them!
I think I will have to stash this one somewhere in the back yard or under the deck (This is where I feel like I may have a hoarding problem!) for a while and get busy wrapping up at least one or two of the current projects and find new homes for them to make some room.
Thanks Jensen,First the simple things :
Choke position ?
Battery voltage ?
Fuel cap ?
Thanks for the tip. Is it a dumb question for me to wonder if this might be a timing advance issue?You could do a plug chop at 5000–6000 rpm, for both cylinders, you have to confirm yourself that the engine doesn't run lean.
It’s not a race. Tuck it away for when you do.While I certainly respect the advice given, I can say with 90% certainty that I simply won't have the time to delve into a plug chop before the snow flies. In the meantime I would welcome any suggestions that might involve late night tinkering in the garage because that's probably the only blocks of time available to me right now. I have so much spare time in the winter and virtually none in the summer months.
Thanks Wentwest. I am grateful for everyone who has chimed in and am not stuck in my thinking so I wouldn't rule out any previous suggestions. Goodness knows my knowledge is non-existent compared to the sage advice I receive here. That being said, I too have been thinking all along that it just "feels" like a fuel supply issue. 2 weekends ago I completely drained the fuel tank and blew it out to make sure there was no debris, dismantled the petcock, made sure it was clean, and blew air through the passages. Same with the fuel lines. Both petcock and fuel lines are essentially new so any debris would have to be recent. The mechanic that put things together after rebuilding the engine did install a couple of low end in line filters but even with those, there seems to be lots of fuel making it's way through to the end of the lines, although I can't quantify it. At the same time I gave the carbs a bath and blew them out just to be sure...BUT...the one thing that I didn't check was float levels and thank you for the suggestion. It feels like the bike gets going well enough and then there just isn't enough fuel available to sustain it for long. Tomorrow I will re-plumb it without the inline filters and check the float levels to see if there is any difference. This might be my last opportunity of the season to actually do a little work and then take it for a test ride due to a busy fall schedule with family stuff.As logical as all the thoughts have been, I keep thinking you either have fuel supply issues or the fuel level in the carb float bowls are just too low. I'd take off the tank, tip it to a place where you can remove the fuel petcock, remove it and investigate whether there is anything blocking the fuel going to the petcock from maybe a clogged filter. Then make sure the petcock is working correctly, clean the sediment bowl, and re-install it. Check the flows. Maybe just replace the fuel lines, but at least blow them out.
Other than the electrical issues already discussed, make sure the exhaust system has no obstructions at all. My bomber had later pipes on it and the inner layer of one down pipe was separated and completely blocked the exhaust. It wouldn't fire at all, just burp back through the carb. I confirmed it by trying to push a plumbing snake through. Complete failure. You could have a partial blockage.
A question for anybody who might know...at a given rpm at a standstill in neutral, will the bike consume the same volume of fuel as it would at that rpm in gear on the highway? In other words, does the bike need more fuel to sustain 6000 rpm in 4th gear as it does to sustain 6000 rpm in neutral? I'm not suggesting running the bike at 6000 rpm in neutral in the driveway for any length of time, just a hypothetical question?
ok. Just wasn't sure if each cycle of the piston drew in an identical volume of fuel & air (in this case roughly 225 cc per side) regardless of how the energy produced is being utilized.No, basic physics. To overcome the resistance of, for example, air, tires to road, etc, the load is much higher when doing 6000 rpm in neutral. When the load is higher, the engine needs to deliver more energy, resulting in opening the throttle, thus more air / fuel mix.
You got it. There's an overflow outlet up the carb body just above the float chamber and when the valve doesn't close properly it leaks out.I would think that the only way the fuel level can get high enough in the bowl to run over the top is a float valve not closing properly?
@wentwest has the trick. If that doesn't work you might have to take the carb apart and have a look.deliver a gentle but firm BONK to the side of the carb body
Maybe but I think a high fuel level in the float chamber would cause the bike to stumble and die so may be unrelated.the excess fuel and the high idle are quite possibly related?
A very plausible explanation considering the battery is weak at best.Aside from an accidentally disconnected wire at the coils due to removing the carbs, a battery holding less than 12v would at least cause weaker spark and can cause only one coil to spark if low enough.
I know. It's frustrating at times. I have spared no expense and never cut a corner but somehow true success eludes me.You guys are giving the Black Bomber a bad rap. OK, at times it deserves it...
@Troy don't get too bummed out. I don't have anything clear to recommend but I have read all your threads and I'm sure you'll get there.
For now... but it won't forever. Not making fun at all, but at some point you will have addressed anything the bike needed that hadn't already been done. Gremlins will still happen now and then, it does to all of our bikes at some point no matter how closely we look at them. But maintaining the simplicity of the older systems on these bikes beats the hell out of dealing with ultra-expensive electronics on modern stuff that can be just as "reliable".but somehow true success eludes me.
This is how I know that Troy and I are cosmically linked. I’m watching this thread, but be forewarned I’m in the weeds and may start another thread. It’s one of those events that make me think… “teebo, you’re an idiot. Somehow. Idiots never know.”1) Not returning to idle. After a good run at highway RPM it doesn't return to idle.
That could well be and very worth checking.Might be leaky floats are heavy and won't close. You could remove them in place and give them a shake to hear gas inside, then you know.
Looking forward to seeing some pics of your S90 and maybe a video of it running. I have to get the new fork gaiters on my 65 and run the pre-flight check list for the season especially check the cam chain tension.Cleaned the inside of my truck and spent a little time with the S90. It is ready for fuel and a kick. Need to paint the fenders and tank, then I can do the final assembly and test ride it.
Me too! Busy at work right now and a trip to Vancouver next week so it might be 2 or 3 weeks but it's close.Looking forward to seeing some pics of your S90 and maybe a video of it running. I have to get the new fork gaiters on my 65 and run the pre-flight check list for the season especially check the cam chain tension.
Just the one. I'll take care of that.I don't know about your other valve adjustment shafts, but the left exhaust adjuster shaft is rotated to the wrong orientation.
I don't see how that is different than my photos? What am I missing?This is the correct orientation of the points wire terminals so they don't short on the points cover.
Seems logical.I plastered a strip of electric tape on the inside of the points cover so if things are too close there's some insulation.
You do realize the valve will need to be readjusted, right? Just want to make sure you understand that you can't just rotate it around without pulling the valve cover and going through a regular adjustment, during which you rotate the shaft so the index mark points the right direction.Just the one. I'll take care of that.
Yours - note how low the right cylinder's terminal is hanging down because it is 180 degrees from how the example I showed you is.I don't see how that is different than my photos? What am I missing?
Not sure how it can be if the screw holes are aligned and the screws in and tightened.Went back for a closer look. Realized that the breaker assembly was sitting low on the points base.
Of course. Or you could simply put a piece of paper between the other set of points that you're not adjusting.1 - commonly I see folks using a test light for checking the static timing. As this requires the ignition to be on, is there any reason why one couldn't leave the ignition off and use a multimeter to check for continuity when the points are opening and closing? To me this seems to be a plausible method as then you have an audible indication?
Timing light is the simplest way to see the marks return to the idle setting.2 - As the spark advancer is a known problem, is there anything I can look for at this stage to observe any problems? It seems to move smoothly and returns to it's resting state without any problem but I'm too ignorant to know what I might see as a problem. I realize that a timing light is the next step but that assumes the bike is running, which it isn't currently. When the time comes we'll talk about that.
Yes, I do. Thanks.You do realize the valve will need to be readjusted, right?
Got itYours - note how low the right cylinder's terminal is hanging down because it is 180 degrees from how the example I showed you is.
There is a tiny bit of vertical clearance and it must have just snagged up when I was there last time and tightened the screws. I just loosened up the screws and gave it a little wiggle and it set back into place correctly. I didn't notice it originally because it isn't obvious when viewed from slightly above.Not sure how it can be if the screw holes are aligned and the screws in and tightened.
If you're talking about the entire points plate, they do sometimes fit a bit loosely in the base. Know that just refitting the plate will change your points gaps and timing as a result, so that will need to be done again.There is a tiny bit of vertical clearance and it must have just snagged up when I was there last time and tightened the screws. I just loosened up the screws and gave it a little wiggle and it set back into place correctly. I didn't notice it originally because it isn't obvious when viewed from slightly above.
yes & yes. That's my plan. I will be checking everything carefully before I button it all up. Once again, I have learned something today. ThanksIf you're talking about the entire points plate, they do sometimes fit a bit loosely in the base. Know that just refitting the plate will change your points gaps and timing as a result, so that will need to be done again.
The way I have done it is to disconnect the points from the coil. Just pull the points' bullet connectors out from their connections. Don't turn on the ignition, no need. Now you can use your continuity meter to your heart's content without worrying about the coil etc. I use a continuity light but if your continuity meter has a relaible noise maker that works too.1 - commonly I see folks using a test light for checking the static timing. As this requires the ignition to be on, is there any reason why one couldn't leave the ignition off and use a multimeter to check for continuity when the points are opening and closing? To me this seems to be a plausible method as then you have an audible indication?
