kinorot
Hello!
Recently I got a 1978 CB400A Hondamatic. I am new to fixing motorcycles so please forgive my lack of knowledge and terminology.
As of right now, I think the carburetors and the brakes are the only thing I need to fix to get it running. The left carburetor has a crack on it, which I’m sure can’t be fixed so I’ll need to buy a new set.
Now to the reason I’m here. I was inspecting the right front brake, and wasn’t getting any pressure to the brakes when pulling the lever. I initially thought that the line was clogged, but I found that the piece that the lever actually pushes in and springs back out was stuck pushed in. I got it released and now there’s movement and I’m seeing pressure within the brake reservoir, but the rubber that surrounds the little push piece was rotted and cracked. I’m assuming that this is supposed to be airtight. Is there a replacement for the rubber part that I’m able to buy? Or do I have to buy a whole new front brake lever assembly to replace it?
Any advice would be appreciated! Thanks!
