CrazyChucky
Hi all! I've got all the old gas cleaned out of my CB350 and it starts and runs, but before I worry about tuning it all up, I wanna go ahead and fix the kickstarter — which matches the description in this thread — since I'll have to open up the lower crank case.
I'm pretty mechanically inclined, have done a good bit of reading and video-watching, and used to regularly ride and (somewhat inconsistently) maintain this very bike, so I've comfortably gotten as far as removing everything in the way: exhaust pipes / studs, brake pedal, drive sprocket, carbs, foot peg bracket, starter motor, and even the ignition switch and horn just to give myself as much room as possible.
Now I'm at the point of the actual removal itself. Both the Honda and Clymer manual are pretty glib about just pulling it out on the right side. I've seen suggestions online of using a hoist, or if the frame is bare, putting the engine on its side and sliding the frame down over it. Is that viable with the tires and forks and all attached? What's the best way to do it myself, and/or would I really be better off requisitioning a friend?
