You may have to grind a couple of flats on the rod and use some vise grips to turn the rod carefully. Edited ... the rod is all that you can twist as the spring is locked into threaded part which in turn is locked into the steering stem. You could drill a small hole through the threaded piece to get some penetrating fluid to the threads. There is a fair bit of meat around the threads.
This is what mine looks like off the CB350View attachment 11649
Honestly I'm thinking of threading a 35 watt soldering iron onto the tip of the threaded rod (even if it's a poor fit) and monitoring temperature with an infrared temp gun.
It most likely won't be too much heat, but maybe it'll get some results.
Thoughts?
Thoughts?
Gentle tapping with a small drift on the "nut" that the fingers are attached to, and even the fingers themselves, can promote penetration of lube as well or better than heat. Or in addition to heat.
Agree. don't destroy anything. Looks like you have turn the star nut against the knob. Gentle vise grips between the fingers end on?
I think the Seafoam Deep Creep will do the job, I just need to allow it enough time. It came very highly recommend by more than a few people I've spoken with. I'll try to check on it tonight, work is picking up.
I don’t know if anyone has suggested scrubbing rusty chrome parts with a wad of aluminum foil doused in Coca-Cola (followed by a rinsing and light polish with some Simichrome or Autosol metal polish), but it works pretty well and is easy to do. Here are a couple examples from my Honda 350 cleanup about 6 years ago. Of course, it won’t restore missing chrome, but it is much easier than trying to clean larger chrome parts with Evaporust.
View attachment 11666View attachment 11667View attachment 11668View attachment 11669
Capitol idea! I'll bring my brass drift and hammer next time I'm over there, thank you.
Even water works with aluminum foil.
Nice brake venting too.Thanks! Here is the finished product.
That was a holdover from its cafe racer days back in the late 1970s. Now I wish I hadn’t done it, but it is what it is.
I hear you on that. If I'm riding that hard it's on back roads in the middle of nowhere.
