Bench Notes: Analyzing the CB-F Titanium WAGIRI Exhaust and the Flaws of OEM Thermal Mass
Webike Japan
Yokohama, Japan
Greetings, fellow builders and metallurgy obsessives. A beautifully fabricated Titanium WAGIRI (pie-cut) exhaust pipe for the classic CB750F/900F/1100F series recently arrived at our shop's workbench. Naturally, I couldn't resist tearing down our demo build to perform a meticulous side-by-side comparison with the factory steel setup. The engineering disparity is profoundly striking.
The unforgivable weakness of the OEM exhaust is its immense thermal weight and restrictive internal geometry, choking exhaust velocity at peak RPMs. But this WAGIRI setup? Every single pie-cut slice is TIG welded with absolute millimeter-level precision. The material rigidity of this aerospace-grade titanium is simply extraordinary, drastically reducing overall weight and elegantly exposing the inherent sluggishness of the original heavy flanges.
When wrenching on these iconic air-cooled motors, the terror of thermal drift from extreme exhaust temperatures is a serious threat. Radiant heat soak can warp delicate exhaust port tolerances and wreck your tuning baseline. Yet, the rapid thermal dissipation and bulletproof structural density of this titanium design efficiently manage extreme heat cycles, neutralizing flange flex entirely. Dialing in your cylinder scavenging with this high-velocity system is a true revelation for crisp throttle feedback.
I have a question for the seasoned vintage tuners here: when transitioning to a rigid, ultra-light titanium manifold like this, how do you precisely dial in your carburetor settings to counteract the altered heat soak characteristics during heavy mid-summer stints without adversely affecting your midrange power delivery?
The post above reads much like it was written with AI assistance and discusses a four-cylinder platform that falls outside the main focus of this forum.
In order to generate more interest in your posts, it might be helpful to highlight products for the motorcycles that occupy most of the attention here, which are largely 60s through 80s Honda twin cylinder motorcycles.
Genuine content is more likely to engage members than AI content, in my opinion.
