Just ordered 2Available in M6x1.00 and M6x0.75 threads and comes with a 15" tube, this one was mentioned over at SOHC4 where this is called, "the clear tube method".
https://www.ebay.com/itm/204117788121?hash=item2f865e45d9:g:rYwAAOSwq99jRb7g&var=504657473006
EBay Item Number 204117788121
Been meaning to get one in M6x .75. Just did. Thanks.Available in M6x1.00 and M6x0.75 threads and comes with a 15" tube, this one was mentioned over at SOHC4 where this is called, "the clear tube method".
Exactly - gives more than the static check and can help determine if you've got a slowly sinking float, etc. Also, on some of the carb models it's really difficult to get the thing tilted just right to set the level.Call me a goof-ball... what is the purpose for doing this?
Is it a way to confirm the float level of the carb?
Thank you... it seemed like that could work.Exactly - gives more than the static check and can help determine if you've got a slowly sinking float, etc. Also, on some of the carb models it's really difficult to get the thing tilted just right to set the level.
