ballbearian
Lots of my brake pedals and handlebars have small vice-jaw marks, but I'd rather have straight than perfect shine, cuz I'm cheap too.
The bench is nice but way too clean.
Did you try to adjust the nut on the end of the brake rod to compensate? If you turn that nut counter clockwise as viewed from behind the bike, it should increase free play. Hopefully it's not out of room for adjustment.If I adjust the stopper bolt to clear the exhaust pipe then I dont have enough free play for the rear brake. Does that make sense??
I did. Granted the shoes are new, so that might make a difference, but to get the pedal to clear the pipe using the stopper bolt, and having the proper amount of pedal travel, the adjusting nut on the end of the rod is only on about half way....... meaning the rod is only half way thru the nut......before disassembly the rod was thru that nut a good amount. If that's not a problem, then I could make that work......maybe lock time the threads?Did you try to adjust the nut on the end of the brake rod to compensate? If you turn that nut counter clockwise as viewed from behind the bike, it should increase free play. Hopefully it's not out of room for adjustment.
Bummer. The minimum free play is supposed to be 20 mm. If you go to that minimum with the smallest possible clearance on the muffler, where will that get you on the adjuster nut? I would want the rod to be at least flush with the end of the nut.I did. Granted the shoes are new, so that might make a difference, but to get the pedal to clear the pipe using the stopper bolt, and having the proper amount of pedal travel, the adjusting nut on the end of the rod is only on about half way....... meaning the rod is only half way thru the nut......before disassembly the rod was thru that nut a good amount.
Got it....Thank you!Bummer. The minimum free play is supposed to be 20 mm. If you go to that minimum with the smallest possible clearance on the muffler, where will that get you on the adjuster nut? I would want the rod to be at least flush with the end of the nut.
There is a brake pedal available from CMS in the Netherlands and it appears to be on sale (no joke). $60 plus shipping. Pricy, but would go well with your very clean build.
PEDAL,BRAKE for CB360G 1974 USA - order at CMSNL
✓Good to order: PEDAL,BRAKE ✓Manufacturercode: 46500-369-000 ✓Quality partwww.cmsnl.com
Thank you PJ. That's incredibly generous of you.I know I have a couple I won't be using but for the life of me can't remember where they are. (last time I saw them was around 2010, they are in a storage tote in one of the sheds or maybe 'buried' in the garage?)
If I find one you can have it for the cost of shipping.
As for handlebars, straightening them is always just a temporary measure.
Even though fitting wiring back inside can be a PITA it's really the best thing to do.
There are probably hundreds of 'good bars' around so should be easy to get hold of
I remember wondering how in the world one can tell a brake pedal arm has the correct shape while working on my CB350 project. The one that came with the bike was so banged up that I just assumed it would have the wrong shape and got another one on eBay. My other clue was that the lower sections of the frame were also bent and damaged.
While this is acceptable under proper circumstances, unless you know the condition of the rear brake shoes it isn't always advisable to reset the arm on the splines in case the shoes are excessively worn. The reason is something that could end badly if the shoes are really worn out. The factory typically puts an alignment dot on the arm and on the end of the actuator shaft, and those dots are intended to be aligned when the arm is reinstalled on the splined shaft. This shaft picture is not one for a 360, but they're all basically designed the same.I noticed I could re-clock the drum actuater lever on the splines a bit to give me more adjustment on the rod.
Note the flat sides where the shoes sit at the inner (left in the picture) end of the shaft, and the cam action that opens the shoes when you push the pedal and the arm on the splines rotates the shaft a bit. If you reset the arm on the splines when old, worn shoes are in use, the flat sides of the cam can sometimes rotate until they are perpendicular to the flats on the ends of the brake shoes - and the rear wheel locks, with no control to release the shoes. This is why Honda put alignment dots on the arms and shafts. Just thought it should be explained in case you weren't aware.
Yes, the later versions had the "solid" area as seen in his picture. I was concerned about they way the earlier versions were when there was no solid area to limit the amount of splines you could move to, and I've seen people unaware of the excessive wear on the shoes and move as much as 2 to 3 splines backwards to get more pedal, which risks turning the shaft too far.Because of the way the shoe spindle is made, you have a very limited chance of 'over adjusting' because there are no splines machined so operating arm can't be moved too far.(although I have seen them opened up and forced on in wrong position)
And in one case the lock-up was so violent it shattered the backing plate. But that was the one and only time it happened to me when I was 15 and stupid, and it was not on a Honda rear wheel/brake either (in fact, most of that bike wasn't Honda except the tired C200 engine)Yep, you've probably seen them go completely over center as well then lock wheel up tearing brake rod from pedal wrapping it around wheel spindle.
Ahhh, sometimes, I really don't miss 'the good old days'![]()
You don't need a battery in the bike to set your static timing. In fact, you are better off never involving your bike's battery to do that task. If you use a battery powered continuity tester, like this for example:. . . Stopped short of using the test light as I have no battery for the bike yet.
Yes,it'll make your coils smileYou don't need a battery in the bike to set your static timing. In fact, you are better off never involving your bike's battery to do that task. If you use a battery powered continuity tester, like this for example:
There is an AA battery and a small 1.5V bulb inside the handle. The wire lead has an alligator clip to attach it to the points connection, or even to the spring-bar of the points. The probe of the tool then goes to any good ground spot on the engine. Stuff it into a small bolt hole or anywhere it will stay temporarily. If the points are closed, the light inside the handle will be on. When the points break open as you rotate the crankshaft, the tester circuit will lose continuity and the bulb will shut off. Set your points by watching for the test light to shut off just as the timing marks align.
Doing it this way, there is 0% chance of leaving the ignition turned on too long and melting the potting material in your spark coils. That is true because you are testing with the ignition turned off, or even with no battery in the bike at all.
Darryl,I'll suggest you replace the long special air filter bolt w/ the two hold-down nuts w/ a used original,because they fit and work very well compared to a length of all-thread,imo.
Just having a hard time wrapping my head around a $35 bolt.....and $35 D-shaped boots.![]()
Thank you. You’ve confirmed what I was thinking. New territory for me.So I would patch the tank with the JB Weld and build a decent strip along there where those small holes are present. As you noted it is likely thin along that whole area. So building a base over the entire bottom of the flat area on both sides isn’t out of the question. I use TechSteel which may not be available to you in the US. Same type of material as JB Weld but I feel it is superior in a temperature rating and quicker set up. Neither of those criteria are an issue in your case, as long as the JB weld is chemical resistant.
Then use the Detox C my preferred rust remover and fill the tank and leave it for a few days empty then into a container for reuse if needed. Then flush the tank with hot water and it shouldn’t flash rust and see where your at then.
I think your likely going to need to line it, yet you want to see what it looks like after the Detox treatment. You may get lucky with a rust removal only process. Good you have the camera to see into the area afterwards to determine if it is clean enough or if a liner is required.
With the Detox C use hot water when you mix the initial batch to assist with the chemical reaction. It will cool down over time, yet warm water is the way to go initially
I can't speak to JB Weld products, yet I will assume they are close to the chemical mix of the Tech Steel product I use. It is totally impervious to gasoline and really any other chemicals such as brake fluid etc that I have used it on in repairs.I defer to Flyin900's excellent advice, but just reacted to point out that there is a specific JB weld product for gas tanks. I'm not entirely certain if it differs in any substantial way from the usual stuff.
GotchaDeox C and JB Weld to the rescue. Kind of a Batman and Robin combo.
Looking really good internally and the liner is likely not needed. Just be aware that the ethanol in gas today is very hygroscopic. I would keep the gas tank more on the full than partially full when left in storage or for longer layups.
Don't forget that underside gas cap section too. The vent in the cap can get plugged from rust or gunk and cause running issues, if air can't get into the tank for pressure equalization. Just flip the tank upside down with the cap submerged over a container of the Deox C for good results.
I looked again and now see the logo - they're Daiichi points if I'm not mistaken, and they're well-known to be below average quality.Havent replaced them. Contact surfaces look smooth and clean so I planned to leave them for now. My plan is (was) get it running with stock ignition and upgrade later to EI. When I saw they were stamped Japan on one end and what appeared to me as logo on the other end I (probably mistakenly) assumed they were original
Ok. That helps a ton. I’ll do that. Thanks!I looked again and now see the logo - they're Daiichi points if I'm not mistaken, and they're well-known to be below average quality.
And all the fiber washers are in place as shown in the picture I posted? You could try testing them off the points plate to be sure they work as they should.
Still strange though. Moments like this are when you just have to see it in person, and it's a shame so many of us are nowhere near each other.Everything seems to be as it should……insulating washers in place….continuity breaks as it should when points were removed from plate. Partzilla had Denso points, so they’re on the way. Fingers crossed
Was thinking that earlier…..I’ve been trying to figure it out for some time now. Kept thinking I was doing something wrong, Hopefully it’s a quality issue.Still strange though. Moments like this are when you just have to see it in person, and it's a shame so many of us are nowhere near each other.
When the points are removed from the plate and the wires, does briefly touching one wire to ground with the key on give a spark on that plug?Was thinking that earlier…..I’ve been trying to figure it out for some time now. Kept thinking I was doing something wrong, Hopefully it’s a quality issue.
I’ve yet to install the new battery, hence the powered tester I’ve been using. I was afraid I’d fry coils static timing. I’d read somewhere that’s a possibility. ?When the points are removed from the plate and the wires, does briefly touching one wire to ground with the key on give a spark on that plug?
It is, but only if you take 15 to 20 minutes or more and don't use a piece of paper between the contacts of the other set you're not adjusting (as I mentioned above).I’ve yet to install the new battery, hence the powered tester I’ve been using. I was afraid I’d fry coils static timing. I’d read somewhere that’s a possibility. ?
