I hope you do replace the cable;I love OEM stock Honda.suggestions needed. New throttle cable is short by a few mm. (chinese ebay) If i put in in the bracket as is it holds the throttle open. top side is fully up against the adjuster so cant give any more. Do i bend the bracket or try and find new cables? This is with the carbs and not cable not routed as they should be so there were less bends.
top side is fully up against the adjuster so cant give any more. this is just the pull cable alone, although the cables came as a set. stock honda i cant find. 4-into1 has a motion pro pull only.What about the adjustment of the other cable at both ends? Or are you just using the pull cable alone?
Knowing yours is a 1983 model, looking at 4into1, they list a "repro" pull-cable for the 1982 CB650SC Nighthawk that is 47 and 7/8" long and a Motion Pro pull-cable for the 1982 CB650SC Nighthawk that is 48.25" longThe motion pro cable shows length of 40.25", slack of 4 1/8", but the one I've got shows 47.5" length and 4.5" slack so I cant see how the motion pro one could work.
I thought of cutting sheath/housing/insulation off too, but it'd be pretty risky or challenging to avoid cutting into the cable strand right when you cut thru the metal of the sheath...maybe dremel som housing off the top end?
I'm leaning toward thinking you've got an early 1983 that came new with 1982 cables or a 1982 set-up ?The one i've got shows 47.5" length and 4.5" slack so I can't see how the motion pro one could work.
Does the inside of your headlight case have molded-on spots toward the back where the large multi-wire plugs get pushed into ?is there any illustrations or pics of the inside of the headlight casing? I got the 4 way hazards working but cannot get the headlight back in. its not the wires i added either, it has to be how the big harnesses are routed. PITA!
no, just openings and 2 clamps on the sides (#12Does the inside of your headlight case have molded-on spots toward the back where the large multi-wire plugs get pushed into ?
I would consider moving all the largest plugs to the back of the headlight case,to get more room.no, just openings and 2 clamps on the sides (#12
Good to hear the reverse bleeding worked-out.finally got the original m/c reverse bled and working only see that my cables not routed correctly.
I want to hear what it was like for you when you spray that 2K clear;I hope it goes well.bike is ready to roll, just need to finish clear coating the tank with the heavy 2k stuff, last warm day tomorrow for a bit. I may need an extra support bracing for the rear rack if it bounces too much. leaving the turn signals non-led for now. Also need to read the date on the tires and order new ones.
Honda chose Yokohama for the OE tires on my '85 XR350R.anything bad on dunlop D404's? currently has kenda challengers on it.
I like that bikelowered windscreen and changed front turns to LED, tested. my hazard button is a little iffy but works if i mess with it. waiting on new brackets to lower the rear rack and a return brake spring. have new tires but need to get those installed. its pretty cold here.
