Thought I'd make a thread for our 1976 CB360T. The plan is to just get it back to looking stock. My dad got it for $750 around this time last year, while I was at school out of state. When 'you know what' hit back in March, I came home for the rest of the semester and I've been home since then, working on this bike and another bike.
Overall we got it in great cosmetic condition... paint looks great, no rust, gas tank near immaculate, etc. the reason it was priced low was because it was missing many many parts, as you can tell from the picture: headlight, headlight stay, master cylinder, brake lines, caliper + pads, front and rear turn signals + stems, mirrors, reflectors + their brackets, more stuff, and LOTS of small little pieces I had to track down on ebay and partzilla. Needless to say I've spent my fair share of hours on CMSNL's part diagrams.
First thing I did was remove the carbs to take a look at them. They'd probably been sitting for at least 10 years is my guess, because the gas had solidified and crystalized literally everywhere, they were by FAR the worst carbs I'd ever seen. I tried cleaning them for the better part of a day and hardly made a dent, so I got a pair of used Keihins on ebay that came off another cb360t.
Next I tracked down all the parts I needed to complete the front disc brake assmebly: caliper, pads, hard line, 2 soft lines, banjo bolts and crush washers, the 3-way joint that also functions as the screw-in for the front brake pressure switch (bought it used on ebay), and master cylinder. Once I had all that stuff I installed the brake system, bled the system with DOT 3 and called it good.
Electric start wasn't working initially, but after installing a new solenoid it's working.
Next headed to 4into1.com to get turn signals and stems. Bought the rear turn signal grounds/mounts on ebay.
Bought like 2 dozen small rubber pieces and hardware from Partzilla and my local Ace after consulting CMSNL part diagrams and figuring out every little piece I was missing around the bike.
Bought new switchboxes, and after sorting through a sea of wires figured out the wiring, they look great.
Headed to those guys in Houston.com to get a headlight bulb+bucket kit, bought a used stock headlight stay on ebay. Installed the headlight and turn signals today. Here's a thread that documents some troubles/questions I had with the process, lol: https://www.vintagehondatwins.com/forums/index.php?threads/970
I'll get better pictures tomorrow of what the bike looks like now but here it is. May not look like much progress, but one thing I've learned is that tracking down what parts you need, buying them, installing them, etc. takes way longer than one would think.
Onward...
Onward...
