Clavertonman
I bought the CB77 from the these three pictures
and a video of the machine running. The last owner (who never rode it and has several CB77s among other bikes, and needed the space) bought it six or seven years ago from a person who apparently used it regularly. Here it is tucked up in the garage.
It was a bit too red when I got it, this was fixed with new tank badges and after a lot of hammering to remove a fork slider jammed with a bit of broken damper valve, replacement the very rough chrome hand painted red fork seal holders, and the fork gaiters with shrouds. It has had a Thai mudflap (fitted reasonably well and looks OK, a Thai chainguard (of which the best that can be said is that it covers the chain - this also involved welding the broken front outer mounting), a Thai clutch cable (just fits, could do with being 50mm longer, and I had to file down the clutch end nipple), a David Silver spares throttle cable- (fitted properly after I'd filed down the throttle end nipple). I don't know how original the paint is, and I've found a reasonable red that will do as I don't intend to properly restore it. Might even repaint it black - the original registration document says black, though subsequent ones say red. The brakes work now, the carbs don't overflow and I've put a quick releaseself sealing petrol coupling in the reserve fuel line, so it's possible to remove the tank without draining it - I'd forgotten about that little surprise ... (though why 15mm OD fuel pipes so they wouldn't fit properly onto the fuel tap). The front mudguard is non standard and will do for now, the speedo packing is positively horrid and a Thai one is in its way - (I await it with interest and anticipation!). The new mirrors and exhausts are from David Silver spares (the old exhausts were missing their baffles and rotted out inside - looks like the case is stainless and the baffle partitions are mild) - and are fitted to pattern pipes that are just slightly the wrong shape. A lot of packing and fiddling and they fit now. Not started it yet so I'll have to see how well the joints seal. On that subject, why would somebody fit two plain washers in the head to pipe joint instead of the proper crush washer - they are easy enough to get - and why a wrong throttle cable (knackered and too short), a wrong clutch cable (would have been OK if it wasn't for the incorrect and rusty chrome curved steel tube section at the handlebar end making it too long and impossible to route). And what's the problem with running the wiring harness correctly? Though the last has meant the discovery of TESA tape - magic stuff! - so it's been divested of the blue and black PVC tape and the split gray tube and rewrapped with some extra wires for indicators and a running light. Thinking that a 61 year old selenium rectifier may not be the most reliable charging solution a Sparck Moto replacement is on its way. I'll leave the alternator wiring through the headlamp switch as it is for now. Most surprising finds so far are the felt rings for the brake cam shafts, and the grease nipples for the kickstart shaft and clutch release. The fifth shot is the key fob I've just spent a horrific sum on - nice. though, isn't it?
The last shots are of it in its interim state. More to follow, and I hope to be riding it in a month or so This is a first posting, so please forgive me if it's badly formatted
