bladen
Hi all! This is a thread dedicated to my new to me CB350K4. I am not mechanically trained or experienced - but my dad is and I grew up helping him wrench on cars - so my knowledge is limited, and my budget is also quite limited. But, I have done much research and studying the FSM and feel I can do anything on this bike adequately given enough research and willpower.
The bike is cosmetically pristine, however there are some minor issues. Bike started first kick and revved cleanly when I bought it but died consistently at idle. PO did not have airboxes but still rode it around fine for a few miles. I took it home and wanted to hear her run but starting required covering carburetor intakes with a towel, but after starting it idled fine but adding throttle meant it’d reach 2.2k rpm and then die quietly.
So, airboxes were purchased and attached, bike started after a few kicks and died at 2.2k rpm, concluded that the carburetors need to be cleaned. I had never done this and just followed some basic videos on this - removed and disassembled carburetors and soaked jets and emulsion tubes (one of which was completely clogged) in carb cleaner for about 45 minutes. noticed left side diaphragm has some small holes near lip. The holes are minor and seem to not drastically cause issues but replacements were ordered (4into1) and are being shipped. Set float height to 23mm when resting (will re set to 26mm following FSM soon, followed misinformation from those guys in Houston). Shot compressed air through the jets and emulsion tubes, and reassembled the carbs with new orings.
Carbs reattached, realized I did not clean the internal passages of the carb nor did I clean the pilot jet. Alas, determined to get it running well enough to ride it for the first time I tried to start her up after adjusting the throttle cable slack and pilot screw to factory spec.
Bike starts, idles a bit rough and low so I adjust the idle butterfly screws. then it idles around 1.2k and revs cleanly through the entire range. Satisfied, I take it for its first drive (with airboxes attached) and it drives nicely and reaches speeds smoothly with power through the entire range! I had a great time until it died at a stop sign a mile away and wouldn’t start unless choked. I get it running enough to get back home and as soon as it reaches idle it quietly dies. Will start briefly with choke but then eventually die without throttle. Turns out, battery has died.
Concluded that the regulator is likely bad, causing weak spark at idle speeds and dying at low rpm. I also believe the idle circuit is clogged and is deserving of a thorough cleaning. Currently the battery is on a trickle charger and replacement parts are on order for the diaphragms. The graphite gasket on the right side muffler to header connection is also missing, causing and exhaust leak at the muffler - the gasket I ordered did not fit - so I’ll be expanding the right side muffler a tiny bit to get it to fit properly and ensure lack of exhaust leak (if the new gasket coming does also not fit).
When I get home today I will reset idle screws to factory spec and see if it starts up with a fully charged battery. Next week when my parts and tools arrive i’ll be doing a valve clearance check and adjustment, go through the points gap and timing adjustments per the FSM, replace spark plugs, replace regulator, replace the diaphragms and fully clean the carbs. Any suggestions as to what I should cover as I get the bike up and running would be appreciated and I will keep this thread updated with new developments.
Thanks,
Bladen
Thanks,
Bladen
